查看: 7228|回复: 9
CIC滤波补偿的问题
发表于 2008-10-14 11:17:29 | 显示全部楼层 |阅读模式
altera CIC IP自带的补偿用的matlab程序,怎么不能正确编译;高手指点一二 谢谢!
程序如下:
%% Legal Notice: Copyright (C) 1991-2007 Altera Corporation
%% Any megafunction design, and related net list (encrypted or decrypted),
%% support information, device programming or simulation file, and any other
%% associated documentation or information provided by Altera or a partner
%% under Altera's Megafunction Partnership Program may be used only to
%% program PLD devices (but not masked PLD devices) from Altera.  Any other
%% use of such megafunction design, net list, support information, device
%% programming or simulation file, or any other related documentation or
%% information is prohibited for any other purpose, including, but not
%% limited to modification, reverse engineering, de-compiling, or use with
%% any other silicon devices, unless such use is explicitly licensed under
%% a separate agreement with Altera or a megafunction partner.  Title to
%% the intellectual property, including patents, copyrights, trademarks,
%% trade secrets, or maskworks, embodied in any such megafunction design,
%% net list, support information, device programming or simulation file, or
%% any other related documentation or information provided by Altera or a
%% megafunction partner, remains with Altera, the megafunction partner, or
%% their respective licensors.  No other licenses, including any licenses
%% needed under any third party's intellectual property, are provided herein.
%% Generated by: CIC 7.2 Build 151 October, 2007
%% Generated on: 2008-4-15 17:59:26
% ratechangecic_core_fir_comp_coeff genearats CIC compensation filter coefficients
% using frequency sampling method.
%    ratechangecic_core_fir_comp_coeff(L, Fs, Fc, plot, is_fxp, B) calculates compensation
%    filter coefficients and saves the coefficients to a file.
%    L      - FIR filter length (= number of taps = number of coefficients)
%    Fs     - FIR filter sample rate in Hz before decimation
%    Fc     - FIR filter cutoff frequency in Hz
%    plot   - True or false to draw filter responses graphically
%    is_fxp - Indicating if the coefficients should be saved as fixed point or floating point numbers
%    B      - Number of bits to represent the coefficients if is_fxp is true
%    Examples:
%    ratechangecic_core_fir_comp_coeff(31,80e6,4e6,true,true,16);
%    ratechangecic_core_fir_comp_coeff(31,80e6,4e6,true,false)
function ratechangecic_core_fir_comp_coeff(L, Fs, Fc, plot, is_fxp, B)
try
% Validate number of input arguments
error(nargchk(0, 6, nargin));
%%%%%% CIC filter parameters %%%%%%
R = 2;     %% Decimation factor
M = 1;     %% Differential Delay
N = 5;     %% Number of Stages
%%%%%% User Parameters %%%%%%
% Check if Signal Processing Toolbox is in the Matlab installation
if (isempty(which('fir2')))
  error('Matlab Signal Processing Toolbox isn''t installed on your machine. Please contact Altera for help.');
end
%% Get user parameters: B, L, Fs, Fc if they aren't passed as arguments.
if(nargin < 1)
     %% Filter length: it must be an odd number, otherwise it'll be increased by 1.
  L = input('Number of filter coefficients (31 as default): ');
  if isempty(L)
   L = 12;
  end
    end
if mod(L,2) == 0
  fprintf('FIR filter length must be an odd number. %d is used instead.\n',L+1);
  L = L+1;
end
if(nargin < 2)
     %% FIR filter sample rate in Hz before decimation
  Fs = input('FIR filter sample rate in Hz before decimation (80e6 as default): ');
  if isempty(Fs)
      Fs = 80000;
     end
end
if(nargin < 3)
     %% FIR filter cutoff frequency in Hz
  Fc = input('FIR filter cutoff frequency in Hz (4e6 as default): ');
  if isempty(Fc)
   Fc = 4000;
     end
    end
    if (nargin < 4)
     plot_res = input('Do you want to plot filter responses? Y/N [N]:','s');
  if isempty(plot_res)
   plot_res = 'N';
  end
  if upper(plot_res) == 'Y'
   plot = true;
  else
   plot = false;
  end
    end
if(nargin < 5)
  fxp_coeff = input('Do you want to write out coefficients as fixed point numbers? Y/N [Y]:','s');
  if isempty(fxp_coeff)
   fxp_coeff = 'Y';
  end
  if upper(fxp_coeff) == 'Y'
   is_fxp = true;
  else
   is_fxp = false;
  end
    end
if(is_fxp && nargin < 6)
  %% Number of bits to represent fixed point filter coefficients
  B = input('Number of bits to represent the filter coefficients (16 as default): ');
  if isempty(B)
      B = 8;
     end
end
Fo = R*Fc/Fs;                            %% Normalized Cutoff freq; 0<Fo<=0.5/M;
                                          %% Fo should be less than 1/(4M) for good performance
% Fo = 0.5/M;                            %% use Fo=0.5 if we don't care responses outside passband
%%%%%%% CIC Compensator Design using fir2.m %%%%%%
p = 2e3;                                 %% Granulatiry
s = 0.25/p;                              %% Stepsize
fp = [0:s:Fo];                           %% Passband frequency samples
fs = (Fo+s):s:0.5;                       %% Stopband frequency samples
f = [fp fs]*2;                           %% Noramlized frequency samples; 0<=f<=1;
Mp = ones(1,length(fp));                 %% Passband response; Mp(1)=1
Mp(2:end) = abs( M*R*sin(pi*fp(2:end)/R)./sin(pi*M*fp(2:end))).^N; %% Inverse sinc
Mf = [Mp zeros(1,length(fs))];
f(end) = 1;
h = fir2(L-1,f,Mf);                      %% Filter order = filter length (L) - 1
h = h/max(h);                            %% Floating point coefficients, scaled it to 1
% Output filter coefficients to a file for Altera FIR Compiler           %
filename = 'ratechangecic_core_fir_comp_coeff.txt';
fid = fopen(filename, 'wt');
if (fid == -1)
  errMsg = sprintf('Can''t Open file %s for writing.\n', FileName);
  error(errMsg);
end;
if (is_fxp) % coefficients are fixed point
  hz = fix(h*(2^(B-1)-1));               %% Quantization of filter coefficients
  fprintf(fid, '%d\n', hz); %% fixed point coeff
else
  fprintf(fid, '%.6f\n',h); %% floating point
end
fclose(fid);
fprintf('The compensation filter coefficients have been saved to file ''%s''.\n',filename);
% Change the following variable to 1 if you would like to plot the filter responses
if (plot)
  if (is_fxp)
   plot_responses(R,M,N,hz,Fs,is_fxp);
  else
   plot_responses(R,M,N,h,Fs,is_fxp);
  end
end;
catch
rethrow(lasterror);
end;
%% Function for ploting filter responses
function plot_responses(R,M,N,res,Fs,is_fxp)
try
%%%%%%% Full resolution CIC filter response %%%%%%%%
hrec = ones(1,R*M);
tmph = hrec;
for k=1:N-1
     tmph = conv(hrec, tmph);
end;
hcic = tmph;
hcic = hcic/max(hcic);
%%%%%%% Total Response %%%%%%%%%%%%%%%
resp = upsample(res, R);
ht = conv(hcic, resp);              %% Concatenation of CIC and fir2 FIR at high freqency
no_data_points = 4096;              %% Number of data points to plot in the figure
[Hcic, wt] = freqz(hcic, 1, no_data_points, Fs);      %% CIC Freq. Response
[Hciccomp, wt] = freqz(resp, 1, no_data_points, Fs);  %% CIC Comp. response using fir2
[Ht, wt] = freqz(ht, 1, no_data_points, Fs);          %% Total response for CIC + Compensation fir2
warning off all;                                      %% Turn the 'Log by zero' warning off
Mcic = 20*log10(abs(Hcic)/(abs(Hcic(1))));            %% CIC Freq. Response
Mciccomp = 20*log10(abs(Hciccomp)/(abs(Hciccomp(1))));%% CIC Comp. response using fir2
Mt = 20*log10(abs(Ht)/(abs(Ht(1))));                  %% Total response for CIC + Compensation fir2
warning on;                                           %% Turn warnings on
figure;
plot(wt, Mcic, wt, Mciccomp, wt, Mt);
  legend('CIC','CIC Comp','Total Response (Fixed Point)');
else % floating point
  legend('CIC','CIC Comp','Total Response (Floating Point)');
end
ymax = max(Mciccomp)+1;
ylim([-100 ymax]);
title('CIC and its Compensation Filter Responses');
grid;
xlabel('Frequency Hz');
ylabel('Filter Magnitude Response dB');
catch
rethrow(lasterror);
end;
发表于 2008-10-15 08:18:41 | 显示全部楼层
ddddddddddddddddddddd
发表于 2009-3-30 11:34:40 | 显示全部楼层
应该没有问题的
发表于 2009-5-2 10:59:04 | 显示全部楼层
看不懂~~
发表于 2009-10-17 19:53:19 | 显示全部楼层
应该不会有问题吧
发表于 2009-11-13 16:08:20 | 显示全部楼层
f(end) = 1;
这一块应该就是产生滤波器系数的程序了
发表于 2010-7-1 10:52:08 | 显示全部楼层
XXX
XXX
发表于 2011-8-8 18:26:49 | 显示全部楼层
没有问题啊
发表于 2016-5-24 20:28:24 | 显示全部楼层
可以看下understanding CIC compensation Filters
发表于 2018-5-31 05:22:19 | 显示全部楼层
thanks
GMT+8, 2025-12-26 22:00 , Processed in 0.033276 second(s), 5 queries , Gzip On, Redis On.
