楼主: ultrawang
高速电流舵DAC(JSSC论文)
发表于 2009-2-18 21:48:48 | 显示全部楼层
发表于 2009-2-19 16:19:24 | 显示全部楼层
发表于 2009-2-19 16:32:39 | 显示全部楼层
IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 33, NO. 12, DECEMBER 1998
A 10-b, 500-MSample/s CMOS DAC in 0.6 mm2
Chi-Hung Lin and Klaas Bult
Abstract— A 10-b current steering CMOS digital-to-analog
converter (DAC) is described, with optimized performance for
frequency domain applications. For sampling frequencies up to
200 MSample/s, the spurious free dynamic range (SFDR) is
better than 60 dB for signals from dc to Nyquist. For sampling
frequencies up to 400 MSample/s, the SFDR is better than 55 dB
The measured differential nonlinearity and integral nonlinearity
are 0.1 least significant bit (LSB) and 0.2 LSB, respectively.
The circuit is fabricated in a 0.35-m, single-poly, four-metal, 3.3-
V, standard digital CMOS process and occupies 0.6 mm2. When
operating at 500 MSample/s, it dissipates 125 mW from a 3.3-V
power supply. This DAC is optimized for embedded applications
with large amounts of digital circuitry.
发表于 2009-2-19 17:08:02 | 显示全部楼层
haobucuoxiexie
发表于 2009-2-26 09:16:23 | 显示全部楼层
ding a thanks.
发表于 2009-2-26 12:55:09 | 显示全部楼层
谢谢楼住共享
发表于 2009-3-3 17:15:40 | 显示全部楼层
谢谢楼主!!!!~~~~
发表于 2009-3-3 17:18:31 | 显示全部楼层
sdfsdfdfdsf dfddfdf
发表于 2009-4-28 20:15:41 | 显示全部楼层
学习下先
谢谢了!呵呵!
发表于 2009-4-28 22:14:54 | 显示全部楼层
GMT+8, 2025-12-20 06:33 , Processed in 0.018705 second(s), 3 queries , Gzip On, Redis On.
