查看: 5868|回复: 1
请教一个问题:请问什么是show ahead fifo?
发表于 2008-9-5 17:15:59 | 显示全部楼层 |阅读模式
谢谢了!
 楼主| 发表于 2008-9-5 17:34:02 | 显示全部楼层
补充一下:
我在网上查到对show ahead fifo的解释:
show ahead mode allowing the early reading of the next read address.
Show-ahead synchronous FIFO mode treats the rdreq signal as a read-acknowledge signal to minimize the FIFO's read latency. The FIFO outputs data when it is available; assertion of rdreq acknowledges the data and causes the FIFO to output the next data word if available.
是不是指当read_en有效时,数据线上对应的数据就是有效的数据。
不同于一般的memory,读使能有效后1ncycle之后才有有效数据。
请问我的理解对不对?请各位帮忙看看,多谢了!
GMT+8, 2025-12-30 05:58 , Processed in 0.014529 second(s), 5 queries , Gzip On, Redis On.
