查看: 46128|回复: 44
cadence零极点PZ仿真的问题
发表于 2008-8-14 19:39:48 | 显示全部楼层 |阅读模式
在设置扫描PZ仿真
其中companent eval fre 是什么意思,该怎么设置
还有就是扫描变量的frequency那个选项里的add specific points那个怎么设,设置不同的值,计算出的零极都不一样,
怎样设置才能计算出电路正确的零极点
请教了
尝试了很多次都没有个正确的结果,救急啊
谢谢了
发表于 2008-8-14 23:38:28 | 显示全部楼层
同问啊
 楼主| 发表于 2008-8-15 15:57:54 | 显示全部楼层
给盏明灯把,急死了
发表于 2008-8-17 08:11:13 | 显示全部楼层
When I simulate PZ analysis, just leave other settings default.
Component Eval Freq, is at which freq simulator analyzes the circuit. I tried 1Hz and 1Ghz, there's almost no difference in my circuits. So leave it default which is 1 Hz is ok.
Leave "Add specific points" blank.
发表于 2008-8-17 09:41:02 | 显示全部楼层
thanks to you.
发表于 2010-5-13 21:03:40 | 显示全部楼层
Component Eval Freq, is at which freq simulator analyzes the circuit. I tried 1Hz and 1Ghz, there's almost no difference in my circuits ...
foxtree 发表于 2008-8-17 08:11
为啥我仿真出来的零极点都是10Hz一下的呢?见下图
看相频、幅频曲线,不应该啊
发表于 2010-5-17 23:46:56 | 显示全部楼层
发表于 2010-5-17 23:52:11 | 显示全部楼层
发表于 2010-5-17 23:58:23 | 显示全部楼层
发表于 2010-5-17 23:59:43 | 显示全部楼层
GMT+8, 2025-9-16 10:10 , Processed in 0.020859 second(s), 6 queries , Gzip On, Redis On.
