查看: 32787|回复: 252
两本DC-DC Converters新书
发表于 2008-8-6 14:25:08 | 显示全部楼层 |阅读模式
Product Description
Power Supply design is all about detail. And a large part of that detail lies in the practical domain, largely because of the typically small number of microseconds of switching periods involved, and the even smaller tens of nanoseconds of switch transition times --- all these, in effect accentuating various "second-order" effects, that eventually end up playing prime havoc with "normal" expectations of how the circuit should behave. So not unsurprisingly, even after reading several books, most readers still find themselves no closer to the ultimate goal of designing an actual power supply.
Sooner or later, all engineers start realizing the hard fact that designing a switching power supply isn't the trivial task it once seemed to be. But even after years of successfully mastering the underlying theory, the ultimate goal of creating a cost-effective, reliable and commercially viable power supply may still remain a distant dream, since success ultimately hinges on experience. That is, in fact, what clearly differentiates a senior and seasoned power supply engineer from the others --- the ability to navigate and surmount a veritable minefield of tricky issues that can only be learned the hard way, by actual hands-on experience on the job.
This book presents practical knowledge the author acquired rather painfully, while working "in the trenches" for several years in major engineering companies scattered across several continents. This is intended to be the mythical senior engineer's "bag of tricks," finally made available in the form of an easy-to-read book on your shelf. This book will make life for the ambitious power supply engineer much simpler --- besides reducing significantly, the rigorous requirement of having to be a senior engineer's protege for years on end, just to gain a small measure of real success in this field.
* A practical presentation that answers the important question: why is my switching converter behaving so differently than what I was expecting on the basis of my paper design? And how do I bridge that huge gap?
* For the first time, a systematic and thorough discussion of troubleshooting switching power supplies.
* Coverage of AC/DC and DC/DC power supplies.
* Bench Evaluation of semiconductor ICs used in power conversion --- describing standard and unusual techniques mastered by the author, while testing similar chips at National Semiconductor.
* Detailed coverage of vital topics that haven't been covered by available sources --- grounding systems, the subtleties of component datasheets, and using instruments and probes effectively.
* Systematic investigation (type of failure mechanism, topology, etc.) and solutions for 5 years of reported power supply issues on a prominent, public web forum. This approach will ensure that engineers will not repeat the same mistakes.
* A unique, readable style: personal and direct; no mystification--- just the plain truth, easily and logically explained, with plenty of pictures, graphs and plots.
Book Description
The senior engineer's "bag of tricks," on power supplies made available in the form of an easy-to-read book!
See all Editorial Reviews
Product Details
    * Hardcover: 400 pages
    * Publisher: Newnes (September 3, 2007)
    * Language: English
    * ISBN-10: 0750684216
    * ISBN-13: 978-0750684217
Troubleshooting Switching Power Converters A Hands-on Guide By Sanjaya Maniktala.part1.rar
4.77 MB, 下载次数: 541 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-8-6 14:27:33 | 显示全部楼层
第二部分
Troubleshooting Switching Power Converters A Hands-on Guide By Sanjaya Maniktala.part2.rar
3.49 MB, 下载次数: 477 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-8-6 14:31:43 | 显示全部楼层
Stay on the cutting-edge of applied power electronics for energy-saving systems with this invaluable guide to multiple converters, power sources, and the IEEE Industry Standard 519. One of the foremost experts in the field and holder of 28 patents, Derek A. Paice brings you new circuit schematics and easy-to follow methods for practical system analysis using actual field test results.
Preface
Acknowledgments
Nomenclature
1   Harmonic Requirements
2   Power Source Representation
3   Multipulse Methods and Transformers
4   Double-wound Multiphase Transformers
5   Auto-wound Transformers
6   Interphase and Current-control Transformers
7   Calculation of Harmonics
8   Meeting Harmonic Standards
9   Multipulse Circuit Performance
10  Practical Applications
11  Digital Computer Simulations
Appendix: Useful Formulas for Analysis
Bibliography
Index
Power Electronic Converter Harmonics - Multipulse Methods for Clean Power.part1.rar
4.77 MB, 下载次数: 469 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-8-6 14:34:09 | 显示全部楼层
第二部分
Power Electronic Converter Harmonics - Multipulse Methods for Clean Power.part2.rar
3.74 MB, 下载次数: 492 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-8-6 14:41:12 | 显示全部楼层
发表于 2008-8-6 21:14:53 | 显示全部楼层
Thanks
发表于 2008-8-6 23:02:32 | 显示全部楼层
发表于 2008-8-7 00:03:14 | 显示全部楼层
好東西  多謝了
发表于 2008-8-7 08:49:09 | 显示全部楼层
pass pass
发表于 2008-8-7 08:50:03 | 显示全部楼层
路过路过路过
GMT+8, 2025-12-26 18:50 , Processed in 0.027691 second(s), 8 queries , Gzip On, Redis On.
