查看: 72774|回复: 237
PCI规范清单
发表于 2004-12-31 11:02:57 | 显示全部楼层 |阅读模式
[这个贴子最后由strongson在 2005/01/05 12:37pm 第 1 次编辑]
官方网站:http://www.pcisig.com/specifications/
[B]PCI Conventional[/B]
PCI/PCI-X Connector Contact Finish Changes ECN ...
Conventional PCI 3.0 FAQs ...
[U]Conventional PCI 3.0 [/U]
Conventional PCI 3.0 with Change Bar
Change Summary - PCI 2.3 to 3.0
PCI 3.0 Compliance Checklist ...
[U]Conventional PCI 2.3[/U]
Summary of changes from PCI 2.2 to PCI 2.3
Errata against PCI Conventional 2.3 ...
SATA Class Code ECN ...
MSI-X ECN Against PCI Conventional 2.3 ...
PCI 2.3 Compliance Checklist ...
[U]Conventional PCI 2.2[/U]
2.1 to 2.2 Change Summary ...
PCI Local Bus Specification Rev. 2.2
Appendix D -- Class codes updates
Appendix H -- Capability Ids updates
Approved PCI 2.2 Errata ...
Addition of the SMBus to the PCI Connector ECN ...
Power Valid to Reset High-Timing specification ECN ...
Low Profile PCI card ECN ...
Minimum PCB characteristic Impedance for Expansion Cards ECN ...
PCI 2.2 Compliance Checklist ...
[U]Mini PCI[/U]
Mini PCI Specification Rev 1.0
[U]PCI BIOS 2.1[/U]
PCI BIOS Spec Rev 2.1
PCI Firmware Specification 3.0 Draft .5
PCI Firmware Specification 3.0 Draft .9
[U]PCI Power Management 1.2[/U]
PCI Bus Power Management Interface Specification Rev. 1.2
[U]PCI Hot-Plug 1.1[/U]
PCI Hot-Plug Specification 1.1
PCI Standard Hot-Plug Controller and Subsystem Specification 1.0
SHPC Memory Access Granularity ECN ...
SHPC ECN adding PCI-X Mode 2 ...
[U]PCI Mobile Design Guide 1.1[/U]
PCI Mobile Design Guide Rev. 1.1
[U]PCI-to-PCI Bridge Architecture[/U]
PCI-to-PCI Bridge Architecture 1.2
PCI-to-PCI Bridge Architecture 1.2 Change Bar Document
[B]PCI Express[/B]
PCI Express x16 Graphics 150W-ATX Specification 1.0
PCI Express Base Specification 1.0a
PCI Express Base Specification 1.0a - Change Bar
Errata for the PCI Express Base Specification - Revision 1.0a
PCI Express Card Electromechanical Specification 1.0a
PCI Express Card Electromechanical Specification 1.0a - Change Bar
PCI Express Mini Card Specification 1.0
PCI Express Connector High Speed Electrical Test Procedure
PCI Express to PCI/PCI-X Bridge Specification 1.0
Mobile Graphics Low-Power Addendum to the PCI Express Base Specification Revision 1.0 ...
PCI Express ECNs ...
[B]PCI-X 66-533[/B]
PCI-X 2.0a Protocol Spec
PCI-X 2.0a Protocol Spec with Change Bar
PCI-X 2.0a Electrical & Mechanical Specification
PCI-X 2.0a Electrical & Mechanical Specification Change Bar
[U]Errata[/U]
Errata against PCI-X Protocol Revision 2.0a -  Rev B.8 ...
Errata against PCI-X Electrical and Mechanical Revision 2.0a - Rev B.5 ...
[U]Compliance Checklists[/U]
PCI-X Protocol Revision 2.0a Compliance Checklist ...
PCI-X Electrical and Mechanical Revision 2.0a Compliance Checklist ...
[U]ECNs[/U]
MSI-X for PCI-X ...
16-Bit PCI-X ...
DIM Interop ...
Enhanced Configuration Access Mechanism Options ...
[U]PCI-X 2.0 Electrical Report[/U]
PCI-X 2.0 Electrical Report - Rev 1.1 ...
PCI-X 2.0 Electrical Report - Rev 1.1 with Change Bars ...
PCB routing study board file ...
Simulation scripts ...
Simulation results--25 worst cases ...
Python numeric module ...
Python ...
[U]PCI-X Marking Label[/U]
PCI-X card mark ...
PCI-X card mark ...
[U]Additional Resources[/U]
PCI-X 2.0 Q&A ...
a Whitepaper on PCI-X 2.0 ...
a Presentation on PCI-X 2.0 ...
PCI-X 2.0 Momentum Collateral ...
[U]PCI-X 1.0 Archive[/U]
PCI-X 1.0 Specification
PCI-X 1.0 Errata
PCI-X Electrical Subgroup Report
PCI-X Marking Label ECN
PCI-X Marking Label
PCI-X Marking Label
[U]PCI-X 1.0a Archive [/U]
PCI-X 1.0a Specification
PCI-X 1.0a Compliance Checklist
PCI-X 1.0a with Change Bar
PCI-X 1.0a Errata
[U]PCI-X 1.0b Archive  [/U]
PCI-X 1.0b Specification
PCI-X 1.0b Compliance Checklist
[U]PCI-X 2.0 Protocol Archive[/U]
PCI-X 2.0 Protocol Specification
PCI-X 2.0 Protocol Specification with Change Bar
PCI-X 2.0 Protocol Errata (A.26)
[U]PCI-X 2.0 Electrical and Mechanical Archive[/U]
PCI-X 2.0 Electrical and Mechanical Specification
PCI-X 2.0 Electrical and Mechanical Specification with Change Bar
Errata A.20 against PCI-X Electrical & Mechanical 2.0
请大家帮忙找找看可以收集到那些规范了,我将把下载信息添加到本贴中。
如果是有关PCI的书籍,请指明:出版社、书名、作者、ISBN、封面图片、涵盖的PCI规范、下载信息、格式等。
希望跟贴,尽量不要开新贴。
下载信息中的不完整路径都是指论坛ftp。
PCI规范收集整理的地方:/协议规范/Bus/PCI整理/
 楼主| 发表于 2004-12-31 11:38:35 | 显示全部楼层
PCI规范清单
[这个贴子最后由strongson在 2004/12/31 12:05pm 第 2 次编辑]
[出版社]电子工业出版社
[书名]PCI系统结构
[原出版社]Addison Wesley Professional.
[原书名]PCI System Architecture, 4th Edition
[作者]Tom Shanley, Don Anderson.
[ISBN]7-5053-6073-6
[涵盖的PCI规范]
PCI Local Bus Specification version 2.2
PCI-to-PCI Bridge Architecture 1.1
PCI Hot-Plug Specification 1.0
PCI Bus Power Management Interface Specification 1.1
PCI BIOS Specification 2.1
[下载信息]/协议规范/Bus/PCI Bus/pci-4.pdf
[格式]PDF 扫描版
 楼主| 发表于 2005-1-1 14:46:19 | 显示全部楼层
PCI规范清单
[出版社]Addison Wesley Professional.
[书名]PCI Express System Architecture
[作者]Ravi Budruk, Don Anderson, Tom Shanley.
[ISBN]0321156307
[涵盖的PCI规范]
[下载信息]/协议规范/Bus/HyperTransport/Addison.Wesley.PCI.Express.System.Architecture.eBook-LiB/
[格式]chm
 楼主| 发表于 2005-1-4 00:55:03 | 显示全部楼层
PCI规范清单
[这个贴子最后由strongson在 2005/01/05 10:48am 第 2 次编辑]
[出版社]Intel Press .
[作者]Adam Wilen, Justin P. Schade, Ron Thornburg.
[ISBN]0970284691
[涵盖的PCI规范]
PCI Express
[下载信息]见本贴附件
[格式]pdf
11_519_3.pdf
2.77 MB, 下载次数: 3580 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2005-1-6 09:18:24 | 显示全部楼层
PCI规范清单
狂顶!
发表于 2005-1-14 16:17:16 | 显示全部楼层
PCI规范清单
超狂顶
 楼主| 发表于 2005-2-2 22:05:51 | 显示全部楼层
PCI规范清单
[出版社]Newnes
[书名]PCI Bus Demystified
[作者]Doug Abbott.
[ISBN]187870754X
[涵盖的PCI规范]
PCI Local Bus Spec., Rev. 2.2
Mobile Design Guide, Rev. 1.1
Power Management Interface Spec., Rev. 1.1
PCI to PCI Bridge Architecture Spec., Rev. 1.1
PCI Hot-Plug Spec., Rev. 1.0
Small PCI Spec., Rev. 1.5a
PCI BIOS Spec., Rev. 2.1
[下载信息]见本贴附件
[格式]pdf
11_519_6.pdf
1.81 MB, 下载次数: 1128 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2005-2-12 21:55:30 | 显示全部楼层
PCI规范清单
ding
发表于 2005-2-14 12:17:42 | 显示全部楼层
PCI规范清单
ding
发表于 2005-4-1 13:15:32 | 显示全部楼层
PCI规范清单
狂顶
GMT+8, 2025-11-2 14:38 , Processed in 0.327269 second(s), 8 queries , Gzip On, Redis On.
