查看: 4319|回复: 0
CORNER PAD的问题
发表于 2008-7-17 23:19:12 | 显示全部楼层 |阅读模式
为什么我自己制作了TDF文件,然后经过FLOORPLAN之后,四个CORNER PAD却不在四个角上,而是移了一小段距离。比如说BOTTOM左边的CORNER PAD叫corner_ll,它应该在最左下角的角落里,而我的却向右移了一段距离,好象Astro把它当成了普通的PAD了
   小弟跪求答案!!!我的TDF如下:定义的电源PAD省略
Corner Pads
dbCreateCellInst(geGetEditCell) "/home/li_zl/863/863library/HHNEC_C250G_IO240_LIB_5LM" "HN_CORNER_P.FRAM" "corner_ll" "0" "NO" '(0 0)
dbCreateCellInst(geGetEditCell) "/home/li_zl/863/863library/HHNEC_C250G_IO240_LIB_5LM" "HN_CORNER_P.FRAM" "corner_ul" "90" "NO" '(0 0)
dbCreateCellInst(geGetEditCell) "/home/li_zl/863/863library/HHNEC_C250G_IO240_LIB_5LM" "HN_CORNER_P.FRAM" "corner_ur" "180" "NO" '(0 0)
dbCreateCellInst(geGetEditCell) "/home/li_zl/863/863library/HHNEC_C250G_IO240_LIB_5LM" "HN_CORNER_P.FRAM" "corner_lr" "270" "NO" '(0 0)
pad "corner_ll"               "bottom"      ;low_left corner
pad "pad_dirty_VDD1"          "bottom"   1
pad "pad_dirty_VSS1"          "bottom"   2
pad "DEBUG_PORT_0_PAD"        "bottom"   3
pad "DEBUG_PORT_1_PAD"        "bottom"   4
pad "DEBUG_PORT_2_PAD"        "bottom"   5
pad "DEBUG_PORT_3_PAD"        "bottom"   6
pad "DEBUG_PORT_4_PAD"        "bottom"   7
pad "DEBUG_PORT_5_PAD"        "bottom"   8
pad "DEBUG_PORT_6_PAD"        "bottom"   9
pad "DEBUG_PORT_7_PAD"        "bottom"   10
pad "pad_core_VDD1"           "bottom"   11
pad "pad_core_VSS1"           "bottom"   12
pad "DEBUG_PORT_8_PAD6"       "bottom"   13
pad "DEBUG_PORT_9_PAD"        "bottom"   14
pad "DEBUG_PORT_10_PA"        "bottom"   15
pad "DEBUG_PORT_11_PA"        "bottom"   16
pad "DEBUG_PORT_12_PA"        "bottom"   17
pad "DEBUG_PORT_13_PA"        "bottom"   18
pad "DEBUG_PORT_14_PA"        "bottom"   19
pad "DEBUG_PORT_15_PA"        "bottom"   20
pad "pad_dirty_VDD2"          "bottom"   21
pad "pad_dirty_VSS2"          "bottom"   22
pad "DEBUG_PORT_16_PA"        "bottom"   23
pad "DEBUG_PORT_17_PA"        "bottom"   24
pad "DEBUG_PORT_18_PA"        "bottom"   25
pad "DEBUG_PORT_19_PA"        "bottom"   26
pad "DEBUG_PORT_20_PA"        "bottom"   27
pad "DEBUG_PORT_21_PA"        "bottom"   28
pad "DEBUG_PORT_22_PA"        "bottom"   29
pad "DEBUG_PORT_23_PA"        "bottom"   30
pad "pad_dirty_VDD3"          "bottom"   31
pad "pad_dirty_VSS3"          "bottom"   32
pad "corner_lr"               "right"    ;lower_right corner
pad "pad_dirty_VDD4"          "right"   1
pad "pad_dirty_VSS4"          "right"   2
pad "DEBUG_SWITCH_0_P"        "right"   3
pad "DEBUG_SWITCH_1_P"        "right"   4
pad "DEBUG_SWITCH_2_P"        "right"   5
pad "DEBUG_SWITCH_3_P"        "right"   6
pad "P3_0_PAD"                "right"   7
pad "P3_1_PAD"                "right"   8
pad "P3_2_PAD"                "right"   9
pad "P3_3_PAD"                "right"   10
pad "pad_core_VDD2"           "right"   11
pad "pad_core_VSS2"           "right"   12
pad "P3_4_PAD"                "right"   13
pad "P3_5_PAD"                "right"   14
pad "P3_6_PAD"                "right"   15
pad "P3_7_PAD"                "right"   16
pad "SFRDATAADC_0_P"          "right"   17
pad "SFRDATAADC_1_P"          "right"   18
pad "SFRDATAADC_2_P"          "right"   19
pad "SFRDATAADC_3_P"          "right"   20
pad "pad_core_VDD3"           "right"   21
pad "pad_core_VSS3"           "right"   22
pad "SFRDATAADC_4_P"          "right"   23
pad "SFRDATAADC_5_P"          "right"   24
pad "SFRDATAADC_6_P"          "right"   25
pad "SFRDATAADC_7_P"          "right"   26
pad "XOSC_32M_EN_PAD"         "right"   27
pad "XOSC_32K_EN_PAD"         "right"   28
pad "RCOSC_32K_EN_PAD"        "right"   29
pad "RCOSC_16M_EN_PAD"        "right"   30
pad "pad_dirty_VDD5"          "right"   31
pad "pad_dirty_VSS5"          "right"   32
pad "pad_dirty_VDD6"          "top"     1
pad "pad_dirty_VSS6"          "top"     2
pad "P0_0_PAD"                "top"     3
pad "P0_1_PAD"                "top"     4
pad "P0_2_PAD"                "top"     5
pad "P0_3_PAD"                "top"     6
pad "P0_4_PAD"                "top"     7
pad "P0_5_PAD"                "top"     8
pad "P0_6_PAD"                "top"     9
pad "P0_7_PAD"                "top"     10
pad "pad_core_VDD4"           "top"     11
pad "pad_core_VSS4"           "top"     12
pad "P1_0_PAD"                "top"     13
pad "P1_1_PAD"                "top"     14
pad "P1_2_PAD"                "top"     15
pad "P1_3_PAD"                "top"     16
pad "P1_4_PAD"                "top"     17
pad "P1_5_PAD"                "top"     18
pad "P1_6_PAD"                "top"     19
pad "P1_7_PAD"                "top"     20
pad "pad_dirty_VDD7"          "top"     21
pad "pad_dirty_VSS7"          "top"     22
pad "P2_0_PAD"                "top"     23
pad "P2_1_PAD"                "top"     24
pad "P2_2_PAD"                "top"     25
pad "P2_3_PAD"                "top"     26
pad "P2_4_PAD"                "top"     27
pad "P2_5_PAD"                "top"     28
pad "P2_6_PAD"                "top"     29
pad "P2_7_PAD"                "top"     30
pad "pad_dirty_VDD8"          "top"     31
pad "pad_dirty_VSS8"          "top"     32
pad "corner_ur"               "top"   ;upper_right corner
pad "pad_dirty_VDD9"          "left"    1
pad "pad_dirty_VSS9"          "left"    2
pad "REGULATOR_EN_PAD"        "left"    3
pad "EXRESET_PAD"             "left"    4
pad "CLK_XOSC_32M_PAD"        "left"    5
pad "CLK_XOSC_32K_PAD"        "left"    6
pad "CLK_RCOSC_32K_PA"        "left"    7
pad "CLK_RCOSC_16M_PA"        "left"    8
pad "CLK_SF_SEL_PAD"          "left"    9
pad "CLK_HF_SEL_PAD"          "left"    10
pad "pad_core_VDD5"           "left"    11
pad "pad_core_VSS5"           "left"    12
pad "U0_SS_S_PAD"             "left"    13
pad "ADC_IR_PAD"              "left"    14
pad "ALE0809_PAD"             "left"    15
pad "START0809_PAD"           "left"    16
pad "OE0809_PAD"              "left"    17
pad "CLK0809_PAD"             "left"    18
pad "EOC0809_PAD"             "left"    19
pad "CC1000_DCLK_PAD"         "left"    20
pad "pad_core_VDD6"           "left"    21
pad "pad_core_VSS6"           "left"    22
pad "CC1000_DIO_PAD"          "left"    23
pad "POR_PAD"                 "left"    24
pad "POR_DOWN_PAD"            "left"    25
pad "pad_dirty_VSS10"         "left"    26
pad "XOSC_32M_STB_PAD"        "left"    27
pad "XOSC_16K_STB_PAD"        "left"    28
pad "RCOSC_16M_STB_PA"        "left"    29
pad "RCOSC_32K_STB_PA"        "left"    30
pad "pad_dirty_VDD10"         "left"    31
pad "pad_dirty_VSS11"         "left"    32
pad "corner_ul"               "left"   ;upper_left corner
;END
GMT+8, 2025-11-3 12:48 , Processed in 0.015094 second(s), 7 queries , Gzip On, Redis On.
