查看: 49935|回复: 261
【Springer 2008 新书】Low-Power High-Speed ADCs for Nanometer CMOS Integration
发表于 2008-7-17 09:28:42 | 显示全部楼层 |阅读模式
Series: Analog Circuits and Signal Processing
Cao, Zhiheng, Yan, Shouli
2008, XIV, 98 p., Hardcover
ISBN: 978-1-4020-8449-2
Printed on demand, usually dispatched between 3 to 5 days
About this book
Low-Power High-Speed ADCs for Nanometer CMOS Integration is about the design and implementation of ADC in nanometer CMOS processes that achieve lower power consumption for a given speed and resolution than previous designs, through architectural and circuit innovations that take advantage of unique features of nanometer CMOS processes. A phase lock loop (PLL) clock multiplier has also been designed using new circuit techniques and successfully tested.
1) A 1.2V, 52mW, 210MS/s 10-bit two-step ADC in 130nm CMOS occupying 0.38mm2. Using offset canceling comparators and capacitor networks implemented with small value interconnect capacitors to replace resistor ladder/multiplexer in conventional sub-ranging ADCs, it achieves 74dB SFDR for 10MHz and 71dB SFDR for 100MHz input.
2) A 32mW, 1.25GS/s 6-bit ADC with 2.5GHz internal clock in 130nm CMOS. A new type of architecture that combines flash and SAR enables the lowest power consumption, 6-bit >1GS/s ADC reported to date. This design can be a drop-in replacement for existing flash ADCs since it does require any post-processing or calibration step and has the same latency as flash.
3) A 0.4ps-rms-jitter (integrated from 3kHz to 300MHz offset for >2.5GHz) 1-3GHz tunable, phase-noise programmable clock-multiplier PLL for generating sampling clock to the SAR ADC. A new loop filter structure enables phase error preamplification to lower PLL in-band noise without increasing loop filter capacitor size.
Written for:
CMOS analog/RF design engineers, graduate students in the field of nanometer CMOS analog/RF circuit design
Keywords:
  • Analog-to-digital converters
  • Clock-multipliers
  • Deep-submicron CMOS
  • Nanometer CMOS
  • Phase-lock loop
[ 本帖最后由 benemale 于 2008-7-17 09:30 编辑 ]
Low-Power High-Speed ADCs for Nanometer CMOS Integration.rar
1.85 MB, 下载次数: 1534 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-7-17 09:33:04 | 显示全部楼层
第一时间
发表于 2008-7-17 09:38:35 | 显示全部楼层
thanks thanks
发表于 2008-7-17 09:42:25 | 显示全部楼层
楼主真是太强悍了,莫非真来自火星 ?!
发表于 2008-7-17 09:59:40 | 显示全部楼层
楼主真的很强大呀。可惜这个我用不着,但还是要顶!
发表于 2008-7-17 10:05:36 | 显示全部楼层
占个6楼
发表于 2008-7-17 10:15:44 | 显示全部楼层
谢谢了,收下了
发表于 2008-7-17 10:43:30 | 显示全部楼层
good!!!
good!!!good!!!good!!!
发表于 2008-7-17 11:55:35 | 显示全部楼层
good one !!!
发表于 2008-7-17 12:19:13 | 显示全部楼层
Good
A new book
GMT+8, 2025-12-22 10:15 , Processed in 0.026175 second(s), 8 queries , Gzip On, Redis On.
