查看: 2742|回复: 2
请教一点英语翻译
发表于 2008-7-14 21:15:53 | 显示全部楼层 |阅读模式
请教几句话,关于MOS失配的PAPER上的句子
For collecting statistics,128device pairs of each size were measured on every values over four wafers.Although the error bars appear large in this figure, in reality they represent relatively small deviations .For example,devices with W/L=6UM/3 have a spread in the standard deviation of matching of threshold voltage of 3.4 -4.9 mv .This spread is partly due to the nominal process variations from wafer to wafer, and partly due to the dependence of the matching on the electrical dimensions of the device.
发表于 2008-7-17 10:31:47 | 显示全部楼层
spread ==> 擴散
nominal ==> 正常
electrical dimension ==> 電氣角度/範疇
 楼主| 发表于 2008-7-17 12:56:48 | 显示全部楼层
我的理解:
分布
标准
电气范围
GMT+8, 2025-12-16 15:19 , Processed in 0.017221 second(s), 5 queries , Gzip On, Redis On.
