查看: 9016|回复: 5
hex文件读取任务和应用实例(systemverilog)
发表于 2008-7-11 08:52:56 | 显示全部楼层 |阅读模式
用于初始化存储器,省的再用工具进行hex->bin转换,自己改写的,出了什么问题还请各位指教
`define rom_size 16'hffff
module irom64kx8(
input  [15:0] irom_addr,
input  irom_rd_n,
input  irom_cs_n,
output reg [7:0] irom_data_out
logic [7:0] rom_data[`rom_size];
logic [7:0] temp;
int i=0;
int h_mt;
initial begin
read_hex_file("../soft/main.hex",rom_data);
end
always @(*) begin
irom_data_out<=((~irom_rd_n) && (~irom_cs_n))? rom_data[irom_addr]:8'bZ;
end
task read_hex_file(input string file_name , output [7:0] rom_data[`rom_size]);
logic [7:0]  column;
logic [15:0] address;
logic [7:0] len;
logic [7:0] dat;
logic [7:0] check_sum;
int i,fd,code;
//initial all data with zero
foreach(rom_data
rom_data
=0;
fd=$fopen(file_name,"r");
if(fd==0) begin
  $display("hex file not found,please check file path and file name!");
  $stop;            // stop when no such file
end
while(~$feof(fd)) begin
    //find ":" at the beginning of a record
while(1) begin
  if($feof(fd))begin
   $fclose(fd);
   return;
  end
   column=$fgetc(fd);
  if(column==":") break;    // every line begin with ":" int the IntelHex form
end
   code=$fscanf(fd,"%2x",len);
   if(len==0) return;      // stop when no data
   check_sum=len;
   code=$fscanf(fd,"%4x",address);
   check_sum=check_sum+address;
   check_sum=check_sum+(address>>8);  // unsigned check_sum
   code=$fscanf(fd,"%2x",dat);     // data type
   check_sum=check_sum+dat;
   for(i=0;i<len;i=i+1) begin
     rom_data[address]=dat;     // rom_data read data from file
     //$display("rom_data[%6d]=%2h",address,dat);
     address=address+1;
   end
   code=$fscanf(fd,"%2x",dat);   // check data
   if(check_sum!=0) begin
     $display("hex file error:checkcheck_sum is not zero!");
     $stop;
   end
end
endtask:read_hex_file
endmodule
[ 本帖最后由 pengyoust 于 2008-7-11 08:56 编辑 ]
发表于 2008-7-13 03:05:24 | 显示全部楼层
花童装出售
支持。support!
where buy flower girl dresses online?
i'm a bride, will marry next 2 month, i have bought my wedding dress, now i like to know where we buy my flowr girl dresses and prom dresses?
we saw jorma wedding dresses factory, anybody know jorma?
who can help me?
bridal gowns
发表于 2008-7-17 17:11:17 | 显示全部楼层
学习了!
学习了!
头像被屏蔽
发表于 2008-8-7 06:26:08 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-7-3 13:14:34 | 显示全部楼层
谢谢分享
发表于 2010-7-4 10:31:38 | 显示全部楼层
有必要那么复杂吗?直接调用$readmemh不行吗
GMT+8, 2025-12-28 23:46 , Processed in 0.024043 second(s), 8 queries , Gzip On, Redis On.
