查看: 14257|回复: 52
IEEE Transation on Power Electronics\2008\Volum23, Issue4
发表于 2008-7-10 12:47:09 | 显示全部楼层 |阅读模式
High Power Converters
1.Five Level Diode Clamped Inverter to Eliminate Common Mode Voltage and Reduce    dv/dt in Medium Voltage Rating Induction
Motor Drives
2.Power Supply for a High Voltage Application
3.Selective Harmonic EliminationPWM Control for Cascaded Multilevel Voltage Source Converters: A Generalized Formula
4.Tri-State Current Source Inverter With Improved Dynamic Performance
abbr_7e5e86c6f97c9586f61fd1365cca1ee8.pdf
705.57 KB, 下载次数: 22 , 下载积分: 资产 -2 信元, 下载支出 2 信元
2.Power Supply for a High-Voltage Application.pdf
1.53 MB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_bc99604c052c3854ad6dcf5d4a51420a.pdf
894.59 KB, 下载次数: 17 , 下载积分: 资产 -2 信元, 下载支出 2 信元
4.Tri-State Current Source Inverter WithImproved Dynamic Performance.pdf
1.85 MB, 下载次数: 20 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-10 13:15:35 | 显示全部楼层
5.Nonlinear Average Current Control Using Partial Current Measurement
6.Open-Loop Control Methods for Interleaved DCM/CCM Boundary Boost PFC Converters
5.Nonlinear Average Current Control UsingPartial Current Measurement.pdf
729.76 KB, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
6.Open-Loop Control Methods for Interleaved DCM_CCM Boundary Boost PFC Converters.pdf
2.12 MB, 下载次数: 27 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-10 13:17:06 | 显示全部楼层
7.Design of an Auxiliary Converter for the Diode Rectifier and the Analysis of the Circulating Current
8.Novel Direct Current-Space-Vector Control for Shunt Active Power Filters Based on the Three-Level Inverter
9.Analysis of the Instantaneous Power Flow for Three-Phase PWM Boost Rectifier Under Unbalanced Supply Voltage Conditions
abbr_cc849a33951db447f1ce1e283cf0fe52.pdf
1.39 MB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_dedfc60578012db2ee46e34b85978445.pdf
1.17 MB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_05537b3700e76709e8710f104d3bcf2a.pdf
929.06 KB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-10 13:19:10 | 显示全部楼层
10.Application of Discontinuous PWM Modulation in Active Power Filters
11.Test Bench for Grid Code Simulations for Multi-MW Wind Turbines, Design and Control
10.Application of Discontinuous PWMModulation in Active Power Filters.pdf
3.37 MB, 下载次数: 20 , 下载积分: 资产 -2 信元, 下载支出 2 信元
11.Test Bench for Grid Code Simulations for Multi-MW Wind Turbines, Design and Control.pdf
2.04 MB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-10 13:20:26 | 显示全部楼层
12.Admittance Compensation in Current Loop Control for a Grid-Tie LCL Fuel Cell Inverter
13.Analysis and Control of Dual-Output 􀀀􀀀 Resonant Converters With Significant Leakage Inductance
 楼主| 发表于 2008-7-10 13:22:23 | 显示全部楼层
14.Modeling and Design for a Novel Adaptive Voltage Positioning (AVP) Scheme for Multiphase VRMs
abbr_7e34f0cf7610742e3edae6e372bbddc2.pdf
1.65 MB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_060d2bd68d5e986718cae8adbe5fa7a2.pdf
1.27 MB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_fc2df0f46c8e019e7b1fdb163e1b9dea.pdf
1.97 MB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-10 13:25:18 | 显示全部楼层
15.A Full-Bridge DC-DC Converter With Zero-Voltage-Switching Over the Entire Conversion Range
16.Voltage Balancing Control of Diode-Clamped Multilevel Converters With Passive Front-Ends
17.A High-Frequency Resonant Inverter Topology With Low-Voltage Stress
18.Analysis of CLL Voltage-Output ResonantConverters Using Describing Functions
abbr_36b71365f6a23fa1c57a3b55d9dade0a.pdf
853.02 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_9dbd9ab6262717690263dac1bd60f648.pdf
923.29 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
17.A High-Frequency Resonant Inverter Topology With Low-Voltage Stress.pdf
2.37 MB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
18.Analysis of CLL Voltage-Output ResonantConverters Using Describing Functions.pdf
881.48 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-10 13:27:38 | 显示全部楼层
19.A New PWM-Controlled Quasi-Resonant Converter for a High Efficiency PDP Sustaining Power Module
abbr_838e3003c2800899a705c780816c8288.pdf
2.03 MB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-7-10 14:44:02 | 显示全部楼层
good!!!!!!!!!!!
发表于 2008-7-10 14:44:57 | 显示全部楼层
nice!!!!
GMT+8, 2025-12-25 02:31 , Processed in 0.022179 second(s), 4 queries , Gzip On, Redis On.
