查看: 11059|回复: 47
Substrate Noise Coupling in RFICs
发表于 2008-7-10 09:55:10 | 显示全部楼层 |阅读模式
Chapter 1 Introduction. 1.1 Motivation and Objectives. 1.2 Contributions. 1.3 Book Organization.
Chapter 2 Analysis of Substrate Noise Coupling. 2.1. Process Regions. 2.2. Process cross sections. 2.3. Connection of devices to the substrate. 2.4. Noise coupling mechanism. 2.5. Substrate doping profile tradeoffs. 2.6. Substrate Model extraction in the IC design flow. 2.7. Doping Profile Considerations. 2.8. Substrate model extraction kernels. 2.9. Conclusion.
Chapter 3 Experimental Data to calibrate the design flow. 3.1. Introduction. 3.2. The test chip. 3.3. Baseline Isolation. 3.4. Effect of p-guard ring on isolation. 3.5. Effect of n-guard ring on isolation. 3.6. Effect of deep n-well on isolation. 3.7. Effect of deep trench on isolation. 3.8. De-embedding. 3.9. Conclusion.
Chapter 4 Design Guide for Substrate Noise Isolation for RF Applications. 4.1. Introduction. 4.2. Isolation in Low resistivity substrate. 4.3. Isolation vs. Frequency for different isolation structures. 4.4. Effect of back plane connection on the noise isolation in high resistivity aaaaaasubstrates. 4.5. Substrate Contacts: Front side or Backside? Both. 4.6. P+ Guard Ring Isolation. 4.7. P+ and N+ Guard Rings Isolation. 4.8. Floor planning techniques to minimize coupling. 4.9. Circuit techniques to minimize coupling. 4.10. Active guard rings. 4.11. Conclusion.
Chapter 5 On Chip Inductor Design Flow. 5.1. Introduction. 5.2. Integrated Inductors. 5.3. Inductor Design Flow. 5.4. Analytical exploration of the design space. 5.5. Inductor Model and Substrate Parasitics. 5.6. Calibrating the field solver. 5.7. Model fit. 5.8. DFM effects. 5.9. Conclusion.
Chapter 6 Case studies for the impact and remedy of substrate noise coupling. 6.1. Introduction. 6.2. System Level Case study. 6.3.Block Level Case study. 6.4. Device Level Case study. 6.5.Conclusion.
Chapter 7 Conclusion.
Appendix A Scattering Parameters. Appendix B Measurements Setup.
Bibliography
Substrate Noise Coupling in RFICs.part1.rar
4.77 MB, 下载次数: 324 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-7-10 09:58:50 | 显示全部楼层
Substrate Noise Coupling in RFICs.part2.rar
3.16 MB, 下载次数: 298 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-7-11 01:40:07 | 显示全部楼层
good good
发表于 2008-7-12 11:11:40 | 显示全部楼层
好书,谢谢LZ
发表于 2008-7-13 01:18:23 | 显示全部楼层
gfsdfa
发表于 2008-7-13 12:25:07 | 显示全部楼层
tai  fuza  le
头像被屏蔽
发表于 2008-7-17 08:57:21 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2008-7-17 08:58:16 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-31 14:52:33 | 显示全部楼层
不错,帮顶,很清晰
发表于 2009-9-21 21:25:20 | 显示全部楼层
不错啊
好人啊,楼主,下。
GMT+8, 2025-12-30 08:04 , Processed in 0.028589 second(s), 7 queries , Gzip On, Redis On.
