查看: 22285|回复: 62
Xilinx Microblaze Source Code
发表于 2008-6-23 08:25:31 | 显示全部楼层 |阅读模式
Xilinx 软核microblaze源代码。
Xilinx_microblaze_v7_10_a_source_code.rar
402.19 KB, 下载次数: 508 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-23 08:49:01 | 显示全部楼层
Reading design: MicroBlaze.prj
*                          HDL Compilation                              *
Compiling vhdl file "E:/workbench/xilinx_prj/mb_core/mb/carry_and.vhd" in Library work.
ERROR:HDLParsers:3317 - "E:/workbench/xilinx_prj/mb_core/mb/carry_and.vhd" Line 74.  Library Microblaze_v7_10_a cannot be found.
ERROR:HDLParsers:3013 - "E:/workbench/xilinx_prj/mb_core/mb/carry_and.vhd" Line 75. Library Microblaze_v7_10_a is not declared.
WARNING:HDLParsers:3481 - Library work has no units. Did not save reference file "xst/work/hdllib.ref" for it.
Total memory usage is 116272 kilobytes
Number of errors   :    2 (   0 filtered)
Number of warnings :    1 (   0 filtered)
Number of infos    :    0 (   0 filtered)
Process "Synthesize" failed
Started : "Launching ISE Text Editor to edit microblaze_types_pkg.vhd".
这是 用ISE编译的结果,我没仔细看过,但估计有问题吧
发表于 2008-6-23 17:24:49 | 显示全部楼层
see 1 see
发表于 2008-6-24 03:32:34 | 显示全部楼层
发表于 2008-6-24 03:33:26 | 显示全部楼层
发表于 2009-1-23 14:53:01 | 显示全部楼层
thanks.
发表于 2009-2-12 20:40:02 | 显示全部楼层
xie
发表于 2009-3-11 13:58:01 | 显示全部楼层
vhdl source?
发表于 2009-3-12 19:36:48 | 显示全部楼层
VHDL语言的!!
VHDL语言的!!
发表于 2009-8-13 11:19:26 | 显示全部楼层
谢谢~~~
GMT+8, 2025-12-26 01:03 , Processed in 0.028708 second(s), 8 queries , Gzip On, Redis On.
