查看: 27297|回复: 81
LDO new compensation
发表于 2008-6-17 18:16:59 | 显示全部楼层 |阅读模式
Design of High-Performance Voltage Regulators Based on Frequency-Dependent Feedback
             abstract
Abstract- A novel scheme is presented for achieving high
performance low-dropout (LDO) voltage regulators under the
constraint of low supply voltage. This scheme makes use of a
frequency-dependent feedback factor (FDFF). The FDFF has
simple circuit structure and frequency-dependent gain. When it
is used in the proposed LDO, the low voltage operation ability,
wide-band high power–supply rejection (PSR) characteristic and
excellent transient response performance can be obtained.
Simulation results show that this LDO can work properly at
1.2-V supply voltage, and the overshoot is only 1mV, while the
PSR is better than -40dB from dc to 100-MHz. Therefore, the
FDFF based LDO is well suited for low-voltage ripple-sensitive
applications.
Design of High-Performance Voltage Regulators Based on Frequency-Dependent Feedback.pdf
1.62 MB, 下载次数: 458 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-17 18:24:02 | 显示全部楼层
07年的paper不错
发表于 2008-6-17 19:30:12 | 显示全部楼层
xie xie
发表于 2008-6-17 20:56:04 | 显示全部楼层
多谢~~
发表于 2008-6-18 09:29:33 | 显示全部楼层
thanks
thanks
发表于 2008-6-18 09:31:01 | 显示全部楼层
thanks
 楼主| 发表于 2008-6-18 10:27:30 | 显示全部楼层
:victory: :)
头像被屏蔽
发表于 2008-6-19 07:57:07 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-6-19 08:09:51 | 显示全部楼层
thank you
发表于 2008-6-24 12:18:10 | 显示全部楼层
cooooool
GMT+8, 2025-12-13 23:10 , Processed in 0.026314 second(s), 7 queries , Gzip On, Redis On.
