查看: 4049|回复: 13
Organic Light-Emitting Devices: A Survey
发表于 2008-6-9 11:24:50 | 显示全部楼层 |阅读模式
Publisher:   Springer
Number Of Pages:   309
Publication Date:   2003-10-31
ISBN-10 / ASIN:   B0014JUZQU
ISBN-13 / EAN:
Product Description:
Although it has long been possible to make organic materials emit light, it has only recently become possible to do so at the level and with the efficiency and control necessary to make the materials a useful basis for illumination or displays. The early electroluminescent devices provided reasonably bright light, but required high operating voltages, produced only a narrow range of colors, and had severely limited lifetimes. Recent developments, however, make it possible to manufacture organic light-emitting devices that are thin, bright, efficient, and stable and that produce a broad range of colors. This book surveys the current status of the field. It begins with an overview of the physics and chemistry of organic light emitting devices by J. Shinar and V. Savvateev. Subsequenbt chapters discuss the design of molecular materials for high performance devices (C. Adachi and T. Tsutsui) and chemical degradation and physical aging (K. Higginson, D. L. Thomsen, B. Yang, and F. Papadimitrakopoulos). A. Dodabalapur describes microcavity OLEDs, and Y. Shi, J. Liu, and Y. Yang discuss polymer morphology and device performance. Various aspects of devices based on polyparaphenylene vinylenes are discussed in chapters by N.C. Greenham and R.H. Friend and by H. Chayet, V. Savvateeyv, D. Davidov and R. Neumann. Chapters by S. Tasch, W. Graupner, and G. Leising and by Y. Z. Wang, D. Gebler, and A. J. Epstein describe OLEDs based on poly(paraphenylene) and poly(pyridine), respectively. The book concludes with a chapter on polyfluorene-based devices, which show great promise for producing light in all colors from blue to red.
[ 本帖最后由 woainio 于 2008-6-9 11:26 编辑 ]
organic_light_emitting_devices__a_survey.pdf
4.17 MB, 下载次数: 144 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2008-6-17 09:37:07 | 显示全部楼层
thanks
发表于 2008-6-17 13:20:56 | 显示全部楼层
bucuo
发表于 2008-7-28 11:36:37 | 显示全部楼层
Thank you.
发表于 2008-7-28 11:37:35 | 显示全部楼层
发表于 2008-7-28 22:30:30 | 显示全部楼层
又是没钱了
发表于 2008-7-29 09:35:30 | 显示全部楼层
thanks so much!
发表于 2009-5-20 11:32:13 | 显示全部楼层
good!!
发表于 2009-5-20 11:43:52 | 显示全部楼层
good!!!
发表于 2010-6-24 14:31:27 | 显示全部楼层
thanks very much.it is a good book
GMT+8, 2025-12-16 12:10 , Processed in 0.027336 second(s), 7 queries , Gzip On, Redis On.
