查看: 4630|回复: 7
美资公司上海诚聘ASIC,Analog,Backend Place&Route,Product&test(内部推荐)
发表于 2008-6-2 17:15:01 | 显示全部楼层 |阅读模式
美资公司 LSI-Agere 上海研发中心诚聘ASIC,Analog,Backend Place&Route,Product,Test工程师(内部推荐,成功机会更高)
公司研发中心位于上海徐家汇高级写字楼,薪水待遇优厚,部分人员有出国培训机会。
因公司发展需要,急聘存储和网络通讯领域以下职位(部分职位要求有所更新,digital,analog IC空缺职位较多 )。
有意者请将中英文简历发送至:asic_tapeout@hotmail.com
注:本人不是上海、杭州、南京、北京地区的高校毕业生,请大家不必担心简历投给熟人或同学手上的尴尬.
1. Requisition Number :  07-2863
Job Title :  Analog IC Design Engineer
Country :  China (CH)
State/Province/County :  Shanghai
City :  Shanghai
Requirements/Qualifications (Education) :  Functional/Industry Knowledge
Required:
- Minimum of 3-7 years Analog IC Design experience in a product development environment
- Perform transistor level, analog and mixed signal integrated circuit design of various cells and blocks
- Proven Analog IC Design skills
- Proven experimental skills and lab/bench expertise
- Strong written and verbal communication skills in both Mandarin and English
Desired:
- Past experience in PLL, High speed serial and deserial circuit.
Education/Certifications
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
We value the diversity of our people. LSI is an Equal Opportunity Employer
Job Description :  Job Responsibilities:
Duties will include working within a Product Development Team to create (design, layout, and evaluate) new circuit architectures, and to modify existing circuit architectures, verify functionality of designs, prepare and present Design Reviews to internal groups and external customers, write technical reports, attend technical conferences in the areas of data storage and advanced IC design.
Requisition Number :  08-3280
Department Name :  Read Channel Design and Integration
City :  Shanghai
Requirements/Qualifications (Education) :  Required Skills:
? Must be familiar with design concepts and architectures for complex analog signal processing functions including data conversion, switched-capacitor circuits, op-amps, pre-amps, comparators, filters, voltage and current references, phase-locked loops and their application to specific products.
? Experience in circuit design and layout of CMOS, BiCMOS or Bipolar silicon technologies as well as participation leading the development of IC projects is required.
? Experience with spice simulation and IC design CAD tools.
? Hard Disk Drive IC design experience is a plus.
Required Education:
? A minimum of a Masters degree in Electrical Engineering. PhD and/or 3 – 5 years of experience may qualify the candidate for consideration of a 8 or 10 grade level
Responsibilities:
Analog IC Design Engineers work closely with the design team and are responsible for developing design specifications, circuit topologies, performing circuit design, and proving out designs by simulation for storage IC’s from initial concept / specification through final verification of conformance to customer specifications. It also includes preparing block diagrams, schematics, simulation results and design analysis. Evaluate and help characterize prototype units. In addition support marketing in establishing custom IC requirements and providing estimation of new product development cycle time as well as participating in design review and technical discussion. Background should demonstrate good problem solving skills as well as strong intuitive ability and expert communication skills.
Job Description :  Position Description:
A qualified applicant for this position would be responsible for transistor level design and development as well as the modification, validation and evaluation of block architecture and/or the entire IC for hard disk drive applications. The position includes working with a design team including other Analog Designers, System Architects, Test Engineers, and Product Engineers to define, architect, and design CMOS PHY/SerDes IC’s utilized in the mass storage industry.
Full Time - Regular Employee
Requisition Number :  08-2961
Job Title :  Digital IC Design Engineer
City :  Shanghai
Job Qualifications:
- Communicate effectively within a global business environment (must be proficient in both spoken and written English)
- Experience in logic design, synthesis, static timing analysis, and verification
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis, and formal verification
- Experience in developing simulation and verification test benches
- Knowledge of Verilog/VHDL design languages
- Excellent technical troubleshooting and demonstrated problem solving skills
- Must be willing to follow a structured design approach including design for reuse and provide thorough design documentation
Education/Certifications:
Required Degree: BS
Preferred Degree: MS or PhD
Preferred Major: Microelectronics, Electrical Engineering or related discipline
A read channel and hard-disk controller SoC digital IC design engineer's duties include working within a highly motivated product development team to create, modify and verify high speed digital integrated circuits. You will support the cross functional team in taking our concepts through to high volume production and assist us in becoming the market leaders in this Mass Storage (hard disk drive) industry.
- Working with a Architecture/Algorithm Development Team to finalize system architecture for optimal implementation of digital signal processing algorithms, including architectural definition and tradeoffs, die size estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification, formal verification and static timing analysis.
- Perform some transistor level high speed digital integrated circuit design various cells and blocks within custom chips for the hard disk drive industry. Examples of cells and blocks include multiplexers, adders, multipliers, dividers, specific functional macro blocks,
- Work very closely with physical design engineers from floorplan through final parasitic extraction to ensure smallest area and highest performance possible.
Requisition Number :  08-3117
Job Title :  Verification Engineer
City :  Shanghai
Requirements/Qualifications (Education) :  Functional/Industry Knowledge:
Required:
- Minimum of 2-6 years ASIC Verification experience in a product development environment
- Proven ASIC Design Verification skills
- Fluent in Verilog for design verification
- Experience with Specman or System Verilog
- Knowledge of data and telecommunication networking(TDM/IP/ATM/Ethernet)
- Experience with one or more scripting languages: awk, Perl, python
- Superior debugging skills for large ASIC designs
- Adaptable to evolving customer requirements
Desired:
- Past experience in a lead position giving guidance to other engineers
- Experience with C/C++
Required Degree: BS
Duties will include working within a Product Development Team to develop reusable block-level and
ASIC testbenches using HVL. Develop new ASIC verification environments to support ASIC
development. Maintain existing ASIC verification environments. Review RTL architectural and
implementation specifications. Create stimulus drivers, monitors, dataflow models, and test plans to
verify function and performance of advanced multiprotocol networking ASICs. Define and develop
application tests required to verify ASICs meet functional and performance goals. Define and
implement functional coverage plans. Define and implement code coverage plans. Develop testing and
regression methodologies for new verification flow. Coordinate test plan implementation and
regressions with remote team. Incorporate reusability into all aspects of the verification environment.
Develop/maintain/enhance environment tools/scripts/makefiles.
 楼主| 发表于 2008-6-2 17:18:05 | 显示全部楼层
继续
Requisition Number :  08-2881
Job Title :  Backend Engineer Specialized in STA
City :  Shanghai
Required:
- Minimum of 4-6 years experience in Physical Design in a product development environment
- Proven physical design experience
- Expertise in circuit design, place and routing, signal integrity, power analysis, CTS design, DFT,
design rule and connectivity verification
- Strong timing analysis capabilities
- Good analytical and debugging skills
- Extremely disciplined in conducting checks and audits
- Must be technically adept, a strong team player, ability to manage multiple priorities
- Ability to interact intelligently and politely with customers
Desired:
- Familiarity with analog physical design, manufacturing and IC packaging
Education/Certifications :
Required Degree: BS
Duties will include working within a Product Development Team to work on leading edge ASIC
solutions in full custom and SoC environments. Design IC devices in conformance with both
LSI and customer requirements and sound design principles; Place and route(layout)
of integrated circuits to meet design requirements; Prepare project evaluations in conformance
with company policies/procedures; Provide CAD assistance to customer engineers and new staff
as required and/or requested; Keep up-to-date with all technical memos; Attend peer reviews
and provide feedback to ensure success of peer designs. Ideal candidate will have
experience/exposure to ASIC and full custom high-speed digital flows from design handoff
through manufacturing, and with strong timing analysis capabilities. Excellent communication
skills are needed, as the existing team spans multiple locations.
Requisition Number :  07-2688
Job Title :  Product Engineer
City :  Shanghai
Requirements/Qualifications (Education) :  - University graduates with 2 years or more semiconductor product or testing experiences
- Solid background in high speed digital and mixed-signal testing is essential
- Working experiences with ATE. Credence Quartet or HP93K or Teradyne Catalyst will be of advantage
- C++ and/or Perl programming skills
Job Description :  1. To support new product release and manage product characterization for eventual robust production release
2. Drive yield improvement activities at both wafer sort and final test areas and work in conjunction with foundries to reduce product defectivity
3. Manage product costs and drive for cost reduction initiatives
4. Deploy yield engineering tools for analysis and drive for corrective actions
5. Analyze product return from customers to improve test coverage and reduce product dppm
Requisition Number :  07-2682
Job Title :  Test Engineer
City :  Shanghai
Job Description :
1. To support prototype and production releases of new products. Manage debug of test program and hardware and meet product release schedules.
2. Support test program development for implementing changes in new test methodologies for test coverage improvement
3. Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via test time reduction and multiple site test solutions
4. Provide Test Engineering Sustain Support for products throughout their entire product life cycle
发表于 2008-6-2 19:33:57 | 显示全部楼层
谢谢 做模拟的都要博士吗
发表于 2008-6-3 01:25:20 | 显示全部楼层
要求好高
发表于 2008-6-3 04:50:28 | 显示全部楼层
在此公司网站上没看到相关的招聘信息阿
发表于 2008-6-5 17:22:23 | 显示全部楼层
著名公司?
发表于 2008-6-14 13:14:08 | 显示全部楼层
要求好高啊!
 楼主| 发表于 2008-7-21 18:27:18 | 显示全部楼层
ASIC 和 Analog还有部分空缺
实际要求并没有那么高,上面发的是官方要求,如果有基带解调,数字电视解调芯片,视音频解码,图像处理芯片等相关领域设计经验的,一至二年工作经验的都可以试。
GMT+8, 2025-12-24 00:31 , Processed in 0.022571 second(s), 5 queries , Gzip On, Redis On.
