查看: 2381|回复: 4
[原创] DSP2812读写SST39VF800A之C++程序源码
发表于 2008-5-22 22:15:56 | 显示全部楼层 |阅读模式
hotpower 发表于 2008-5-5 23:11 DSP 技术 ←返回版面
楼主: DSP2812读写SST39VF800A之C++程序源码
本演示程序在Study-2812增强版上通过运行测试
菜农HotPower@126.com  2008.5.5  于西安大雁塔菜地
#include "flash.h"
FlashObj::FlashObj(void)
  Init();
  Test();
void FlashObj::Init(void)
  Active = false;
  Busy = false;
  MakerId = 0;
  DeviceId = 0;
  FlashReset();
  ReadId();
  Test();
void FlashObj::FlashReset(void)
  Busy = true;
  FLASH[0x5555] = 0xaa;
  FLASH[0x2AAA] = 0x55;
  FLASH[0x5555] = 0xf0;
  Wait(FLASH[0x5555]);
  Busy = false;
void FlashObj::ReadId(void)
  Busy = true;
  FLASH[0x5555] = 0x90;
  MakerId = FLASH[0x0000] & 0xff;
  DeviceId = FLASH[0x0001] & 0xff;
//SST39VF800A MakerId=0xBF DeviceId=0x81
  Active = (MakerId == 0xBF) && (DeviceId == 0x81);
  FlashReset();
  Busy = false;
void FlashObj::ChipErase(void)
  Busy = true;
  FLASH[0x5555] = 0x80;
  FLASH[0x5555] = 0x10;
  Busy = false;
void FlashObj::SectorErase(unsigned int SectorNum)
  Busy = true;
  FLASH[SectorSize * SectorNum] = 0x30;
  Busy = false;
void FlashObj::BlockErase(unsigned int BlockNum)
  Busy = true;
  FLASH[BlockSize * BlockNum] = 0x50;
  Busy = false;
void FlashObj::Write(unsigned int & address, unsigned int val)
  Busy = true;
  FLASH[0x5555] = 0xa0;
  address = val;
  Wait(address);
  Busy = false;
void FlashObj::Wait(unsigned int & address)
unsigned int temp, val;
  Busy = true;
  do
    _delay_loop_(1);
    val = address;
    _delay_loop_(1);
    temp = address;
  while(((val ^ temp) & BIT6) != 0);
  Busy = false;
void FlashObj::Test(void)
  Busy = true;
  if (Active)//SST39VF800A测试正常
    FlashReset();
    ChipErase();
    FlashReset();
    Write(FLASH[0x0000], 0x1234);
    Write(FLASH[0x5555], 0x1234);
    Write(FLASH[0x2aaa], 0xabcd);
    FlashReset();
    SectorErase(0);
    FlashReset();
    Write(FLASH[0x0000], 0x8888);
    FlashReset();
    BlockErase(0);
    Write(FLASH[0x0000], 0x6666);
    FlashReset();
  Busy = false;
下图是在SST39VF800A上实现的"FLASH二次写入"图例
* - 本贴最后修改时间:2008-5-5 23:12:22 修改者:hotpower
发表于 2009-9-24 00:02:07 | 显示全部楼层
thanks  thanks
发表于 2010-2-23 01:07:36 | 显示全部楼层
谢谢您的程序,正是我想要的!
发表于 2010-2-23 09:06:06 | 显示全部楼层
必须顶啊 狂顶
发表于 2013-4-17 11:08:20 | 显示全部楼层
先标记一下
GMT+8, 2025-12-20 15:38 , Processed in 0.023154 second(s), 7 queries , Gzip On, Redis On.
