查看: 5419|回复: 3
dc综合文体求助
发表于 2008-5-22 19:54:10 | 显示全部楼层 |阅读模式
dc综合的网表有assign语句,这么把它去除啊
dc提示:Information: Please make sure that you have run the 'change_names' command on your design before saving files to disk.  (UCN-2)
Warning: Verilog 'assign' or 'tran' statements are written out. (VO-4)
这是怎么回事啊
发表于 2008-5-22 23:20:48 | 显示全部楼层
这是因为design里面含有feedthrough path或有悬空的端口等造成的。
加个变量就好了,如果还不行,修改你的name rule规定。
 楼主| 发表于 2008-5-23 00:32:52 | 显示全部楼层
我设了
set_fix_multiple_port_nets -feedthroughs -outputs -buffer_constants
还是有assign
请问name rule 怎么改啊
谢谢了
发表于 2008-5-24 14:57:12 | 显示全部楼层
change_names -rule verilog -h
但是MS这个assign没啥影响吧.
GMT+8, 2025-12-23 00:54 , Processed in 0.019780 second(s), 6 queries , Gzip On, Redis On.
