查看: 33560|回复: 162
Analog circuit design paper 仓库(IEEE论文,学位论文....)
发表于 2008-5-9 16:27:20 | 显示全部楼层 |阅读模式
收集的大量的IEEE论文和学位论文,一次贡献出来!
分为几大部分:OpAmp, AD-DA Converter, LDO, BIAS, 学位论文Thesis, 其他
首先是OpAmp
Op-Amp.rar
4.01 MB, 下载次数: 552 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-5-9 16:31:12 | 显示全部楼层
AD-DA Converter
AD-DA Converter
ad-da.rar
1.7 MB, 下载次数: 412 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-5-9 16:34:24 | 显示全部楼层
补充一下
前面发动OpAmp 和AD-DA Converter两个文件内容如下:
OpAmp:
Design of CMOS Op-Amp with low probability EMI induced failure
A bio-amplifier with pulse output 2004
A CMOS IF variable gain Amp with exponential gain control 2005
A general description of common-mode feedback in fully-differential amplifiers
An autozeroing floating-gate amplifier 2001
A low-power low-noise CMOS amplifier for neural recording applications 2003
Fully differential basic building blocks based on fully differential difference amplifiers with unity-gain difference feedback 1995
Three-stage large capacitive load amplifier with damping-factor-control frequency compensation 2000
A slew rate enhancement techniques for operational amplifiers based on a tunable active Gm-based capacitance multiplication circuit 2003
Amplifier Design for Fast Settling Performance
Overview of feed-forward design tech for High-Gain Wideband OTA
High-Drive CMOS Current Amplifier 1998
A high-swing CMOS telescopic OpAmp 1998
AD-DA Converter:
A 1.4-V 10-bit 25-MHz pipeline ADC using OpAmp-reset switching technique 2003
A 1-V 10-MHz clock rate, 13-bit CMOS delta-sigma modulator using unity-gain-reset OpAmps 2001
A 14-b 100-MHz CMOS DAC designed for spectral performance 1999
Low-voltage CMOS circuits for analog decoders
A 10bit CMOS pipeline AD converter
A 13Bit High Gain 3V CMOS Differential Transconductance Amp
接着发LDO:
A frequency compensation scheme for LDO voltage regulators 2004
A low dropout CMOS regulator with HPSR over WB frequency
ldo.rar
704.51 KB, 下载次数: 241 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-5-9 16:36:53 | 显示全部楼层
BIAS
BIAS
An adaptive bias circuits for high effciency power Amp 2000
Biasing CMOS Amp using MOS in subthreshold region 2004
Selective GateLength Biasing for Cost-Effective Runtime Leakage Control 2004
A low-voltage CMOS filter for hearing aids using dynamic gate biasing 2001
Dynamic biased 1MHz low-pass filter with 61dB peak SNR and 112dB input range
Reducing MOSFET 1f noise and power consumption by switched biasing
CMOS limiting optical preamplifiers using dynamic biasing for wide dynamic range 2004
A 1V 1mW CMOS front-end with on-chip dynamic gate biasing for a 75Mbs optical receiver 2001
bias.rar
2.24 MB, 下载次数: 391 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-5-9 16:40:04 | 显示全部楼层
Thesis
Thesis
Analog Baseband circuit for WCDMA Direct-Conversion Receivers 2003
Design considerations for High-Speed Low-Power Low-Voltage CMOS Analog-to-Digital Converters
Low voltage design techniques and considerations for integrated operational amplifier circuits 1995
Analysis and design of CMOS wide-band low noise amplifiers 2004
A switched Opamp comparator to improve the conversion rate of low-power low-voltage successive approximation ADCs 2005
Low Voltage design technique and consideration for OpAmp
Thesis.part1.rar
2.73 MB, 下载次数: 287 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-5-9 16:42:35 | 显示全部楼层
Thesis
第二部分
Thesis.part2.rar
2.49 MB, 下载次数: 259 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-5-9 16:45:09 | 显示全部楼层
其他
其他
A CMOS analog circuit for Gaussian functions 1996
A current-mode CMOS loser-take-all with minimum function for neural computations 2000
A high speed low input current low voltage CMOS current comparator
A linear MOS transconductor using source degeneration and adaptive biasing 2001
A new CMOS differential OTRA design for the low voltage power supplies in the sub-micron technologies 2005
Application of the back gate in MOS weak inversion translinear circuits 1995
CMOS circuit with subvolt supply voltage 2002
Fully Monolithic CMOS RF Power Amplifiers-Recent Advances 1999
其他.rar
2.43 MB, 下载次数: 193 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-9 18:00:48 | 显示全部楼层
谢谢。学习了!
发表于 2008-5-9 19:49:32 | 显示全部楼层
:hug: :hug:
发表于 2008-5-9 22:42:32 | 显示全部楼层
bucuo
GMT+8, 2025-12-28 05:00 , Processed in 0.040993 second(s), 6 queries , Gzip On, Redis On.
