查看: 13519|回复: 50
Synthesis Strategies for Large ASICs
发表于 2008-5-1 04:10:07 | 显示全部楼层 |阅读模式
Table of Contents
1.0 Introduction.....................................................................................................................5
1.1 A Large ASIC Defined ..................................................................................................5
1.2 Design Details................................................................................................................6
1.3 Synthesis Issues .............................................................................................................6
1.4 Synthesis Strategy..........................................................................................................7
1.5 The Design Flow............................................................................................................7
1.5.1 Architecture ...............................................................................................................8
1.5.2 RTL Coding ...............................................................................................................8
1.5.3 Synthesis ....................................................................................................................9
1.5.4 Layout ........................................................................................................................9
1.6 Synthesis Strategy Summary .........................................................................................9
2.0 RTL Studies – Detail......................................................................................................10
RTL Algorithm Coding Example ........................................................................................10
2.1 Synthesis compile Options...........................................................................................11
2.2 Block Partitioning ........................................................................................................13
3.0 The Synthesis Process....................................................................................................15
3.1 Using Makefiles...........................................................................................................15
3.2 Using Revision Control ...............................................................................................16
3.3 Audit Scripts ................................................................................................................16
3.3.1 Design Guidelines....................................................................................................16
3.3.2 Gate Level Audits ....................................................................................................16
3.3.2.1 Example Script – Single Fanout ......................................................................17
3.3.3 Synthesis Script Audit Scripts .................................................................................18
3.3.4 Synthesis Report Audit Scripts ................................................................................19
3.3.4.1 Other Report Scripts ........................................................................................20
3.3.5 Release to Layout Scripts ........................................................................................21
4.0 Conclusions and Recommendations....................
synthesis_techniques_larger_asic_design.pdf
562.32 KB, 下载次数: 238 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-1 09:31:26 | 显示全部楼层
1
11111111111111111111111
发表于 2008-5-5 14:41:44 | 显示全部楼层
看看,谢谢
发表于 2008-5-5 15:11:09 | 显示全部楼层
看看。学习下
发表于 2008-5-6 01:46:54 | 显示全部楼层
Ding DING
发表于 2008-5-6 07:47:05 | 显示全部楼层
好东西
谢谢
发表于 2008-5-6 09:41:42 | 显示全部楼层
发表于 2008-5-6 14:13:39 | 显示全部楼层
2
2222222222222222222222
发表于 2008-5-7 18:35:18 | 显示全部楼层
Thanks!
发表于 2008-5-8 17:41:24 | 显示全部楼层
thanks for share!
GMT+8, 2025-12-17 22:33 , Processed in 0.029438 second(s), 8 queries , Gzip On, Redis On.
