查看: 2638|回复: 2
请教sigma delta仿真
发表于 2008-4-29 10:46:58 | 显示全部楼层 |阅读模式
刚完成晶体管级的SD modulater部分,spectre做了瞬态,由于不熟后面filter的verilog,所以想问下,有没有什么软件能直接对那个300M的瞬态文件做理想DAC,以便我测试modulater的性能。
发表于 2008-5-3 04:16:09 | 显示全部楼层
去找个verilog的code应该很容易吧
发表于 2008-5-3 15:31:45 | 显示全部楼层
Use matlab for the spectrum analysis. Single bit output is easy, just do fft and dBFS. If multibits, do dac using matlab code, and then fft.
You may have large signal spectrum leakage, which makes the signal peak a skirt shape. To avoid this, the input sinusoid frequency must be on the fft frequency bin.
GMT+8, 2025-12-29 13:09 , Processed in 0.018605 second(s), 6 queries , Gzip On, Redis On.
