各位,请教一个简单的问题,我的hspice是200709,在调用库文件时总是报错。
请各位指点迷津
sp文件如下:
*HSPICE SIMULATION FILE EX3-12
.OPTIONS POST=2 LIST
*COMMON-SOURCE USING ACTIVE LOAD
.lib 'C:\synopsys\opConditions.lib'tt
M1 1 1 VDD VDD tt W=8U L=2U
M2 OUT 1 VDD VDD tt W=8U L=2U
M3 OUT VIN GND GND tt W=40U L=2U
IREF 1 0 400U
VIN VIN GND AC 1 SIN(1 0.01 1K)
VDD VDD GND DC 3.3
.PRINT TRAN V(OUT)
.AC DEC 30 1 1G
.TRAN 1M 5M
.END
下面是.lib文件:
**** Nominal Voltage, Room Temperature, Typical Process
.lib TT
.temp 70
.param Supply='Sup'
.prot
.include '100nm_nominal.sp'
.unprot
.endl TT
* SS nl, pl, RCslo Hi temp, lo supply voltage
.lib SS
.temp 125
.param Supply='0.9 * Sup'
.prot
.unprot
.endl SS
* FF nh, ph, RCfas Lo temp, hi supply voltage
.lib FF
.temp 0
.param Supply='1.1 * Sup'
.prot
.unprot
.endl FF
* FS nh, pl, RCnom Hi temp, lo supply voltage
.lib FS
.temp 125
.prot
.unprot
.endl FS
* SF nl, ph, RCnom Lo temp, hi supply voltage
.lib SF
.temp 0
.prot
.unprot
.endl SF
.lib FSM
.temp 50
.param Supply='Sup'
.prot
.unprot
.endl FS
.lib SFM
.temp 50
.param Supply='Sup'
.prot
.unprot
.endl SF
* SLOW nt, pt, RCnom Hi temp, lo supply voltage
.lib SLOW
.temp 125
.prot
.unprot
.endl SLOW
* FAST nt, pt, RCnom Lo temp, hi supply voltage
.lib FAST
.temp 0
.param Supply='1.1*Sup'
.prot
.unprot
.endl FAST
* nt, pt, RCnom med temp, nom supply voltage
.lib TM
.temp 70
.param Supply='Sup'
.prot
.unprot
.endl TM
* nf, pf, RCfast med temp, nom supply voltage
.lib FM
.temp 70
.param Supply='Sup'
.prot
.unprot
.endl FM
* ns, ps, RCslow med temp, nom supply voltage
.lib SM
.temp 70
.param Supply='Sup'
.prot
.unprot
.endl SM
.lib ST
.temp 25
.param Supply='Sup'
.prot
.unprot
.endl ST
.lib flatten
.param Supply=0
.model nmos NMOS LEVEL=1 LD=0 XW=0
.model pmos PMOS LEVEL=1 LD=0 XW=0
.endl flatten
可为什么总是报错:
**error** (C:\synopsys\opConditions.lib:8) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:12) could not find library file named ss
**error** (C:\synopsys\opConditions.lib:15) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:19) could not find library file named ff
**error** (C:\synopsys\opConditions.lib:22) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:26) could not find library file named fs
**error** (C:\synopsys\opConditions.lib:29) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:33) could not find library file named sf
**error** (C:\synopsys\opConditions.lib:36) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:40) could not find library file named fsm
.param Supply='Sup'
**error** (C:\synopsys\opConditions.lib:43) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:47) could not find library file named sfm
.param Supply='Sup'
**error** (C:\synopsys\opConditions.lib:50) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:54) could not find library file named slow
**error** (C:\synopsys\opConditions.lib:57) could not find include file named 100nm_nominal.sp
.unprot
**error** (C:\synopsys\opConditions.lib:61) could not find library file named fast
**error** (C:\synopsys\opConditions.lib:64) could not find include file named 100nm_nominal.sp
.unprot
**error** library number 100 too large
.param Supply='Sup'
**error** library number 101 too large
.unprot
**error** library number 102 too large
.param Supply='Sup'
**error** library number 103 too large
.unprot
**error** library number 104 too large
.param Supply='Sup'
**error** library number 105 too large
.unprot
**error** library number 106 too large
.param Supply='Sup'
**error** library number 107 too large
.unprot
**error** library number 108 too large
**warning** .prot and .unpr not matched, unencrypted information may be enclosed. |
