查看: 4999|回复: 14
FREQUENCY SYNTHESIZER FOR BUILT-IN SELF TESTING OF ANALOG IC
发表于 2008-4-17 20:52:13 | 显示全部楼层 |阅读模式
1 INTRODUCTION..................................................................................................................1
1.1 Background and Motivation ........................................................................................... 2
1.2 Challenges and Requirements......................................................................................... 5
2 SIGNAL GENERATION....................................................................................................... 7
2.1 Signal Generation Techniques ........................................................................................ 7
2.1.1 Direct Digital Synthesizer ...................................................................................... 7
2.1.2 Phase Locked Loop (PLL) Based Synthesizer........................................................ 9
2.1.3 Switched-Capacitor Based Sine Wave Generator ................................................ 10
2.2 Phase Locked Loop Architectures ................................................................................ 11
2.2.1 Integer-N Structure ............................................................................................... 11
2.2.2 Fractional-N Structure .......................................................................................... 13
2.3 Frequency Synthesizer Architecture ............................................................................. 15
3 MODIFIED PLL IN FREQUENCY SYNTHESIZER......................................................... 19
3.1Specifications................................................................................................................19
3.2 PLL Analysis................................................................................................................20
3.2.1 Linear Loop Analysis............................................................................................ 20
3.2.2 Phase Frequency Detector..................................................................................... 24
3.2.3 Charge Pump......................................................................................................... 27
3.2.4 Loop Filter............................................................................................................30
3.2.5 Voltage Controlled Oscillator ............................................................................... 34
3.2.6 Loop Divider......................................................................................................... 39
3.3 Additional Blocks.........................................................................................................43
3.3.1 Frequency Down-Converter.................................................................................. 43
3.3.2 Output Selector ..................................................................................................... 49
4 DESIGN CONSIDERATIONS AND SIMULATED RESULTS ........................................ 50
vii
Page
4.1 Stability Analysis..........................................................................................................50
4.2 PLL Design...................................................................................................................55
4.2.1 Phase Detector ...................................................................................................... 55
4.2.2 Charge Pump......................................................................................................... 59
4.2.3 Voltage Controlled Oscillator ............................................................................... 60
4.3 Frequency Down-Converter Design ............................................................................. 64
4.3.1Mixer.....................................................................................................................64
4.3.2Filter......................................................................................................................66
4.4 Output Selector Design................................................................................................. 66
4.4.1 Fixed Divider ........................................................................................................ 66
4.4.2 2:1 Multiplexer...................................................................................................... 69
4.5 Frequency Synthesizer Simulation ............................................................................... 70
5CONCLUSIONS...................................................................................................................78
REFERENCES.............................................................................................................................
FREQUENCY SYNTHESIZER FOR BUILT-IN SELF TESTING OF ANALOG IC.pdf
1023.33 KB, 下载次数: 115 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-4-18 02:16:18 | 显示全部楼层
好的好的看看看看
发表于 2008-5-24 19:23:59 | 显示全部楼层
Thanks~
发表于 2008-5-25 21:02:24 | 显示全部楼层
Thanks
发表于 2008-5-25 23:44:45 | 显示全部楼层
good resource thanx!
发表于 2008-5-26 15:38:14 | 显示全部楼层
gei hao, mu gai
发表于 2008-5-26 23:03:25 | 显示全部楼层
heng hao heng hao
发表于 2008-5-27 02:31:33 | 显示全部楼层
thanks for your information..........................
thanks..........................................................
发表于 2008-5-27 05:58:46 | 显示全部楼层
thanks!!!
发表于 2008-5-27 21:44:35 | 显示全部楼层
好东西,谢谢分享!
GMT+8, 2025-12-25 21:16 , Processed in 0.025601 second(s), 7 queries , Gzip On, Redis On.
