查看: 175086|回复: 1346
[原创] 【开关电容的好书】Demystifying Switched Capacitor Circuits
发表于 2008-4-5 20:09:27 | 显示全部楼层 |阅读模式
[size=120%]Demystifying Switched Capacitor Circuits (Demystifying Technology, Vol. 1)
By Mingliang (Michael) Liu
    • Publisher:   Newnes
    • Number Of Pages:   318
    • Publication Date:   2006-04-27
    • ISBN-10 / ASIN:   0750679077
    • ISBN-13 / EAN:   9780750679077
    • Binding:   Paperback
    Product Description:
    This book helps engineers to grasp fundamental theories and design principles
    by presenting physical and intuitive explanations of switched-capacitor
    circuits. Numerous circuit examples are discussed and the author emphasizes the
    most important and fundamental principles involved in implementing
    state-of-the-art switched-capacitor circuits for analog signal processing and
    power management applications. Throughout the book, the author presents numerous
    step-by-step tutorials and gives practical design examples.
    While some
    quantitative analysis is necessary to understand underlying concepts, tedious
    mathematical equations and formal proofs are avoided. An intuitive appreciation
    for switched-capacitor circuits is achieved.
    Much of the existing
    information on contemporary switched-capacitor circuit applications is in the
    form of applications notes and data sheets for various switched-capacitor ICs.
    This book compiles such information in a single volume and coherently organizes
    and structures it.
    The author has his own website at
    www.mingliangliu.com
    * Step-by-step tutorials which emphasize the most
    fundamental principals of switched-capacitor circuits
    * Few tedious
    * The first easy-to-understand compilation on this
    subject--most information available is not very cohesive
    Summary: Table of Contents
    Rating:
    5
    Greeting! I am the author Mingliang (Michael) Liu. I noticed there is no link
    to the book's Table of Contents on this Amazon web page (as of October 19,
    2006). Thus, I thought I would add that here, as follows:
    Preface
    Chapter 1: Basic MOS Device Physics
    1.1 Introduction
    1.2
    MOS Transistors
    Basic Operation
    Scaling of MOS Transistors
    1.3
    MOSFET Switches
    Switch On-Resistance
    Charge Injection
    1.4 MOSFET
    Capacitors
    Chapter 2: Operational Amplifiers
    2.1 Introduction
    2.2 Two-Stage Op-Amps
    2.3 Telescopic and Folded-Cascode Op-Amps
    Appendix 2.1
    Chapter 3: Switched-Capacitor Building Blocks
    3.1 Introduction
    3.2 Switched-Capacitor Resistor Simulation
    SC Resistor Simulations
    The Advantages of SC Resistor Simulations
    Capacitance Ratios versus Circuit Parameters
    3.3 Switched-Capacitor
    Integrators
    Parasitic-Sensitive SC Integrators
    Parasitic-Insensitive SC
    Integrators
    Fully Differential Integrators
    3.4 CMOS Sample-and-Hold
    Circuits
    Performance Parameters
    Testing S&H Circuits
    CMOS
    S&H Circuits
    3.5 Switched-Capacitor Interpolators and Decimators
    SC Interpolators
    SC Decimators
    3.6 Signal-Flow-Graph Analysis of
    Switched-Capacitor Circuits
    Mason's Rule
    Appendix 3.1
    Chapter 4: Switched-Capacitor Filters
    4.1
    Introduction
    4.2 Low-Order Switched-Capacitor Filters
    First-Order SC
    Filters
    Second-Order SC Filters
    Area-Efficient High-Q SC Filters
    4.3 High-Order Switched-Capacitor Filters
    Realizations of SC Filters
    Biquad Ordering and Dynamic Range Scaling
    Design Example: An Elliptical
    Low-Pass SC Filter
    4.4 High-Frequency CMOS Switched-Capacitor Filters
    Appendix 4.1
    Chapter 5: Switched-Capacitor Data Converters
    5.1 Introduction
    5.2 Performance Parameters of Data Converters
    DAC Specifications
    ADC Specifications
    INL, DNL, and Quantization
    Noise
    5.3 Nyquist-Rate DACs
    Integrated Nyquist-Rate DACs
    Nyquist-Rate SC DACs
    Matching Accuracy of Data Converters
    5.4
    Nyquist-Rate ADCs
    Flash ADCs
    Two-Step ADCs
    Pipelined ADCs
    Cyclic
    ADCs
    Successive-Approximation ADCs
    5.5 Oversampling Data Converters
    Nyquist Rate versus Oversampling
    Noise Shaping and Stability
    Types
    of Delta-Sigma Modulators
    Delta-Sigma Modulators with Single-Bit
    Quantization
    Delta-Sigma Modulators with Multibit Quantization
    Appendix 5.1
    Chapter 6: Switched-Capacitor DC-DC Converters
    6.1 Introduction
    Types of SC DC-DC Converters
    Applications of SC
    DC-DC Converters
    6.2 Dickson Charge-Pump
    Conventional Dickson
    Charge-Pump
    Improved Dickson Charge-Pumps
    6.3 Cross-Coupled SC
    Step-Up DC-DC Converters
    6.4 SC Step-Down DC-DC Converters
    6.5
    Multiple-Gain SC DC-DC Converters
    Chapter 7: Advanced Switched-Capacitor
    Circuit Techniques
    7.1 Introduction
    7.2 Low-Voltage SC Circuits
    Techniques
    The Low-Voltage Challenge
    Clock Boosting and Switch
    Bootstrapping
    Switched Op-Amp
    7.3 Accuracy-Enhancement Techniques
    for SC Circuits
    The Imperfect Op-Amp
    Autozeroing
    Correlated
    Double-Sampling
    Chapter 8: Design of SC Delta-Sigma Modulators for
    Multistandard RF Receivers
    8.1 Introduction
    The Multistandard
    Challenge
    Delta-Sigma Modulator for Multistandard RF Receiver
    8.2
    Receiver Systems
    Figures of Merit
    Conventional Super-Heterodyne Receiver
    Zero-IF (Direct-Conversion) Receiver
    Low-IF Receiver
    Wideband IF
    Double-Conversion Receiver
    Digital-IF Receiver
    Modulator Specifications
    8.3 System-Level Delta-Sigma Modulator Design
    IF Frequencies and
    OSRs
    Delta-Sigma Modulator Design for GSM and DECT
    Design for WCDMA
    Sizing the Capacitors
    Nonidealities in Delta-Sigma
    Modulators
    8.4 Circuit Implementation
    SC Integrators
    Operational
    Transconductance Amplifier (OTA)
    Quantizer
    8.5 Measurement Results
    8.6 Conclusions
    Index
    Summary: A
    Very Good Buy
    Rating: 5
    As a high-frequency circuit designer who has worked primarily on CMOS
    circuitries, I found the last chapter of the book (on the design and
    implementation of a delta-sigma modulator for multiple-standard wireless
    headsets) to be novel and inspiring.
    This book is a good choice, in
    particular to junior and / or higher-level college students studying analog
    integrated electronics. Some context (filled with light-math derivations, and
    presented in an intuitive, result-oriented style) may not be suitable to
    everybody. Rather, it is more likely to be a comfortable read to a limited
    audience, such as graduate school students and experience design engineers /
    researchers. This book helps me do my job and thus buying it was a good choice
    to me.
    Summary: Don't waste your
    money
    Rating: 1
    I bought this book based on Amazon reviews soon after it was released.
    Looking back I see many of the positive reviews are dated prior to the book
    availability. How can people recommend a book they haven't read?
    I was
    very excited by the table of contents because the topics were exactly what I was
    looking for. However the author failed to deliver anything useful to gaining
    insight on the topics.
    Specific criticisms:
    1) The author writes in
    a rambling stream-of-consciousness style with no apparent direction for anything
    written.
    2) There are no detailed explanations; only the authors tips and
    generalizations.
    3) Equations given with no explanation of what the
    variables represent.
    4) Examples give answers contradictory to the math
    shown.
    5) Inconsistent notation.
    6) Descriptions include nodes that are
    not labeled on the schematics so the reader is left to guess what part of the
    circuit is being discussed.
    7) Large portion of book is MATLAB code with no
    documentation.
    This book demystifies nothing.
    Summary: Worth Buying
    Rating:
    4
    Bought this book 3 wks ago while traveling in the Bay Area. The book , in my
    opinion, is well-structured and detail-oriented. The information presented in
    this book is current and mostly accurate. However, as the author himself has
    pointed out in the preface: The maths have been minimized, the fact of which
    seems both good and bad to me: The good thing is that the book is a simple and
    easy read; but the bad thing is that a few concepts are poorly explained, for
    example, the sensitivity of a switched-capacitor ladder filter seems delibrately
    avoided by the author in my view.
    Of course, there are quite a few
    positive points on the other side of the axis, such as the discussion on data
    converter's resolution in relation to speed and clock jitter, or the anatomy of
    a dc/dc multiple-gain converter, etc. Thus, despite a couple more disappointing
    aspects, on the whole, I rate this book a fairly good reference that is worth
    buying, and more importantly, worth reading/keeping.
    Summary:
    New addition to analog designer's library
    Rating:
    5
    The book is full of circuit design examples and real-world stuff on
    analog/mixed-signal switched-capacitor circuit design. The reference list is
    plentiful and convenient for one to trace all the excitements in this field.
    Would be a good addition to any analog designer's library.
[ 本帖最后由 benemale 于 2008-4-5 20:12 编辑 ]
Demystifying Switched-capacitor Circuits.rar
3.36 MB, 下载次数: 5322 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-4-5 20:31:20 | 显示全部楼层
太好了
强烈期待的东东
发表于 2008-4-5 20:40:28 | 显示全部楼层
帅哥!你已经那么有名了!还要搞个回复!岂不是要爆满了阿!呵呵!
发表于 2008-4-5 20:56:32 | 显示全部楼层
好咚咚么?
 楼主| 发表于 2008-4-5 20:57:57 | 显示全部楼层
原帖由 woainio 于 2008-4-5 20:40 发表
呵呵,只是试试代码好不好使.......
发表于 2008-4-5 21:29:10 | 显示全部楼层
thanks for sharing~
发表于 2008-4-5 21:37:19 | 显示全部楼层
thx a lot
发表于 2008-4-5 22:10:46 | 显示全部楼层
thx a lot
thx a lot
发表于 2008-4-5 22:14:10 | 显示全部楼层
thx!!!!!!!!!!!!!!!
发表于 2008-4-5 22:45:14 | 显示全部楼层
就出书了?
GMT+8, 2025-10-29 02:11 , Processed in 0.024635 second(s), 8 queries , Gzip On, Redis On.
