楼主: dyjguilin
请教关于全差分运放CMFB
发表于 2013-11-19 11:43:53 | 显示全部楼层
共模反馈的带宽要大于等于差模是因为:当输入共模电平增大或减小时,检测到的共模电平也相应增大或减小,增大或减小的量必须立刻反馈到被控制的电流源上,这样才能起到立刻调节的作用。达到速度上的匹配(带宽决越大响应越快)
发表于 2013-11-19 18:16:25 | 显示全部楼层
On system-level, you should first make clear how your input-signal looks like. What is ur signal-modulation type? How much common-mode variation will happen?
On circuit-level, make clear how much SNR your amplifier needs to provide? How much common-mode to diff-mode conversion is tolerant?
after these considerations, you can define your CMRR and CMFB BW clearly.
BR, lightgo
回复 支持 3 反对 0
发表于 2020-9-14 13:55:57 | 显示全部楼层
发表于 2023-7-14 11:07:31 | 显示全部楼层
我觉得CMFB的GBW需要要大于Common Mode的GBW
GMT+8, 2025-10-2 14:37 , Processed in 0.014425 second(s), 3 queries , Gzip On, Redis On.
