查看: 17057|回复: 63
Sample-and-Hold Circuit__論文
发表于 2008-3-14 18:33:41 | 显示全部楼层 |阅读模式
Low Power, High Performance Sample-and-Hold Circuit__論文
This master thesis describes the design of a track-and-hold (T&H) circuitwith 10bit resolution, 80MS/s and 30MHz bandwidth. It is designed in a0.18μm CMOS process with a supply voltage of 1.8 Volt. The circuit issupposed to work together with a 10bit pipelined analog to digital converter.A switched capacitor topology is used for the T&H circuit and the amplifieris a folded cascode OTA with regulated cascode. The switches used are oftransmission gate type.The thesis presents the design decisions, design phase and the theory neededto understand the design decisions and the considerations in the designphase.The results are based on circuit level SPICE simulations in Cadence withfoundry provided BSIM3 transistor models. They show that the circuit has10bit resolution and 7.6mW power consumption, for the worst-casefrequency of 30MHz. The requirements of the dynamic performance are allfulfilled, most of them with large margins
Low Power, High Performance Sample-and-Hold Circuit.pdf
2.33 MB, 下载次数: 487 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-3-14 21:37:13 | 显示全部楼层
QQQQQQQQQQQQQQ
发表于 2008-3-15 02:07:50 | 显示全部楼层
看看怎么样怎么样
发表于 2008-3-15 02:09:14 | 显示全部楼层
太好了太好了
发表于 2008-3-15 13:24:05 | 显示全部楼层
发表于 2008-3-15 17:48:54 | 显示全部楼层
thx a lot
发表于 2008-3-15 17:49:49 | 显示全部楼层
thx a lot
发表于 2008-3-16 01:14:56 | 显示全部楼层
thanks
发表于 2008-3-16 01:15:46 | 显示全部楼层
:victory:
发表于 2008-3-16 09:36:30 | 显示全部楼层
Thanks for sharing!!
GMT+8, 2025-12-25 22:33 , Processed in 0.024604 second(s), 6 queries , Gzip On, Redis On.
