楼主 |
发表于 2019-1-24 14:58:04
显示全部楼层
回复 5# sonson2008
用的是ip核,您看一下
module my_clc
(// Clock in ports
input CLK_IN1_P,
input CLK_IN1_N,
// Clock out ports
output CLK_OUT1,
// Status and control signals
input RESET,
output LOCKED
// Input buffering
IBUFGDS clkin1_buf
(.O (clkin1),
.I (CLK_IN1_P),
.IB (CLK_IN1_N));
// Clocking primitive
// Instantiation of the MMCM primitive
// * Unused inputs are tied off
// * Unused outputs are labeled unused
wire [15:0] do_unused;
wire drdy_unused;
wire psdone_unused;
wire clkfbout;
wire clkfbout_buf;
wire clkfboutb_unused;
wire clkout0b_unused;
wire clkout1_unused;
wire clkout1b_unused;
wire clkout2_unused;
wire clkout2b_unused;
wire clkout3_unused;
wire clkout3b_unused;
wire clkout4_unused;
wire clkout5_unused;
wire clkout6_unused;
wire clkfbstopped_unused;
wire clkinstopped_unused;
MMCME2_ADV
#(.BANDWIDTH ("OPTIMIZED"),
.CLKOUT4_CASCADE ("FALSE"),
.COMPENSATION ("ZHOLD"),
.STARTUP_WAIT ("FALSE"),
.DIVCLK_DIVIDE (10),
.CLKFBOUT_MULT_F (49.875),
.CLKFBOUT_PHASE (0.000),
.CLKFBOUT_USE_FINE_PS ("FALSE"),
.CLKOUT0_DIVIDE_F (33.250),
.CLKOUT0_PHASE (0.000),
.CLKOUT0_DUTY_CYCLE (0.500),
.CLKOUT0_USE_FINE_PS ("FALSE"),
.CLKIN1_PERIOD (5.000),
.REF_JITTER1 (0.010))
mmcm_adv_inst
// Output clocks
(.CLKFBOUT (clkfbout),
.CLKFBOUTB (clkfboutb_unused),
.CLKOUT0 (clkout0),
.CLKOUT0B (clkout0b_unused),
.CLKOUT1 (clkout1_unused),
.CLKOUT1B (clkout1b_unused),
.CLKOUT2 (clkout2_unused),
.CLKOUT2B (clkout2b_unused),
.CLKOUT3 (clkout3_unused),
.CLKOUT3B (clkout3b_unused),
.CLKOUT4 (clkout4_unused),
.CLKOUT5 (clkout5_unused),
.CLKOUT6 (clkout6_unused),
// Input clock control
.CLKFBIN (clkfbout_buf),
.CLKIN1 (clkin1),
.CLKIN2 (1'b0),
// Tied to always select the primary input clock
.CLKINSEL (1'b1),
// Ports for dynamic reconfiguration
.DADDR (7'h0),
.DCLK (1'b0),
.DEN (1'b0),
.DI (16'h0),
.DO (do_unused),
.DRDY (drdy_unused),
.DWE (1'b0),
// Ports for dynamic phase shift
.PSCLK (1'b0),
.PSEN (1'b0),
.PSINCDEC (1'b0),
.PSDONE (psdone_unused),
// Other control and status signals
.LOCKED (LOCKED),
.CLKINSTOPPED (clkinstopped_unused),
.CLKFBSTOPPED (clkfbstopped_unused),
.PWRDWN (1'b0),
.RST (RESET));
// Output buffering
BUFG clkf_buf
(.O (clkfbout_buf),
.I (clkfbout));
BUFG clkout1_buf
(.O (CLK_OUT1),
.I (clkout0));
endmodule |
