查看: 17678|回复: 43
[招聘] 后端好职位(实习生,应届生,engineer和leader)
发表于 2016-2-1 20:09:01 | 显示全部楼层 |阅读模式
公司招聘,后端好职位不要错过。如果有意向可将简历发到hr@magic-semi.com
1. 实习生职位
Magic-semi JD forIntern
Magic-semi is a new startup design servicecompany specialized in backend training, consulting and design service. In magic-semi, design experters with rich experience in advancetechnology nodes from 40nm to 14nm and can deliver complete solutionfrom netlist to GDSII.   Magic-semi has good relationship with IC leadingcompany and enables our customer to achieve success in a more efficient,reliable and cost-effective way.
RESPONSIBILITES:
1. Responsible for developing digital designswith emphasis on backend, including Floor-plan, power planning, Place, CTS andRoute.
2. Work with Front-end designers to optimizetiming/area/power of the design implementation and perform static timinganalysis.
3. Optimization and Verification of layoutfor tape-out (including RC extraction, ECO, DRC, LVS).
4. Static Timing analysis (Prime Time or ETS)and setup/hold fix.
Requirements:
1.
CS/EE or background in areas related todigital or analog chip design
2.
Known of IC backend flow.
3.
Known of timing concept.
4.
Have reading and writing skills forenglish
5.
Experience in floorplan, place, cts,route, timing ,pv and power analysis and so on.
6.
Experienced in Synopsys/Cadenceautomatically physical implementation tools and flows (IC-Compiler/ Astro /SOC-Encounter/ Milky-way/ Star-RCX) is a plus.
7.
Experience with one or more scriptinglanguages (Perl, TCL, or Shell) to make reusable automatically flow is a plus.
8.
Experience and knowledge about FE design(RTL code, flow) and verification is a plus.
9.
Good analytical and debugging skills.
Send your CV to hr@magic-semi.com if you are interested.
2.应届生
Magic-semi JD for NCG
Job Title:
Intern/NCG
RESPONSIBILITES:
2. Work with Front-end designers to optimize timing/area/powerof the design implementation and perform static timing analysis.
Requirements:
1.
2.
Be familiar with IC backend flow.
3.
4.
5.
6.
3. 高级工程师
Magic-semi JD forSenior Engineer
Job Title
Senior Engineer
RESPONSIBILITES:
Requirements:
1.
2.
3 year+ work experience.
3.
experience in floorplan, place, cts,route, timing ,pv and power analysis and so on.
4.
5.
6.
7.
4. leader
Magic-semi JD forLeader Engineer
Job Title:
Leader Engineer
RESPONSIBILITES:
Requirements:
1.
2.
7 year+ work experience for IC backend.
3.
4.
Have experience for project management.
5.
6.
7.
8.
9.
Self-motivated and good team player.
 楼主| 发表于 2016-2-2 10:32:23 | 显示全部楼层
进到公司后会有很正规的后端培训,对于实习生来说是一个很好的机会。
发表于 2016-2-2 20:29:27 | 显示全部楼层
在什么地方?
 楼主| 发表于 2016-2-3 09:15:48 | 显示全部楼层
工作地点:上海张江
 楼主| 发表于 2016-2-3 09:17:22 | 显示全部楼层
想转行到IC后端的也是不错的选择,会有非常系统的IC后端培训。
 楼主| 发表于 2016-2-3 09:18:47 | 显示全部楼层
回复 3# jiushiwokamen
    上海张江
发表于 2016-2-3 09:54:42 | 显示全部楼层
公司多少人?
 楼主| 发表于 2016-2-3 10:54:21 | 显示全部楼层
公司刚成立,要招很多人,现在公司的人都是后端很大牛的,而且会给非常系统的培训
发表于 2016-2-3 12:29:35 | 显示全部楼层
回复 8# magic-semi
卖人头的?还是把项目拿过来自己做?
 楼主| 发表于 2016-2-4 10:23:46 | 显示全部楼层
将来都会有,欢迎发简历到hr@magic-semi.com
GMT+8, 2025-10-6 11:05 , Processed in 0.031862 second(s), 3 queries , Gzip On, Redis On.
