查看: 9400|回复: 3
[求助] virtuoso中Assura的LVS验证出现unbound的错误
发表于 2014-6-21 15:42:32 | 显示全部楼层 |阅读模式
本人大三本科菜鸟,学习virtuoso版图设计中,用assura的LVS验证出现schematics与layout的unbound的错误,具体报错信息如下: QQ截图20140621154010.png
具体的log信息如下:
====File: diode_mimic.err
====File: diode_mimic.csm
Schematic                        | Layout                        | Status
diode_mimic schematic practice   | diode_mimic layout practice   | errors    *
Mismatch between Schematic and Layout
   1 cell with errors
====File: diode_mimic.cls
****** diode_mimic schematic practice  <vs>  diode_mimic layout practice
Filter Statistics
=================                               Original            Filtered
Cell/Device                               schematic  layout   schematic  layout
(ndio18, -) DIO                                   1       -*          1       -*
(-, ndio18) DIO                                   -       1*          -       1*
Reduce Statistics
=================                               Filtered             Reduced
Match Statistics
================                                  Total             Unmatched
Total                                             1       1           1       1
Match Statistics for Nets                         2       2           0       0
==================================================================[diode_mimic]
====== Bad Matched Nets (don't really match) ==================================
= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = =(badmatch 1)
Schematic Net:  vdd!
S      *1   of ndio18 {PLUS MINUS}
Layout Net:  avC1
L      *1   of ndio18 ?{PLUS MINUS}
= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = =(badmatch 2)
Schematic Net:  gnd!
Layout Net:  avC2
====== Problem Schematic Nets (no exact match in layout) ======================
S
S ?vdd! ?gnd!
S (total 2) with:
S       1   of ndio18 {PLUS MINUS}
====== Problem Layout Nets (no exact match in schematic) ======================
L
L ?avC1 ?avC2
L (total 2) with:
L       1   of ndio18 ?{PLUS MINUS}
====== Unmatched Schematic Instances ==========================================
= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (schinst 1)
Schematic Instance: D0  ndio18
S Pin        Net
S ---        ---
S PLUS       vdd!
S MINUS      gnd!
====== Unmatched Layout Instances =============================================
= = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = (layinst 1)
Layout Instance:    avD33_1  ndio18
L Pin        Net
L ---        ---
L PLUS       vdd!
L MINUS      gnd!
====== Summary of Errors ======================================================
Schematic  Layout     Error Type
2          2         Bad Matched Nets
1          1         Unmatched Instances
====File: diode_mimic.cps
; autoPinSwap() results for schematic network.
====File: diode_mimic.cfr
The LVS run "diode_mimic" has completed successfully.
Compare problems were detected in 1 cells.
   1 cells had device mismatches.
   1 cells had nets mismatches.
   0 cells matched
No Extraction Problems were detected.
Press "OK" to enter the LVS Debug Environment.
Press "Cancel" to close this Dialog box.
LVS Run "diode_mimic"
is located in /home/guest/zzf
原理图和版图如下:
求哪位高人指点一下解决思路。
 楼主| 发表于 2014-6-21 15:46:49 | 显示全部楼层
用的PDK是SMIC18MS的
 楼主| 发表于 2014-6-22 16:40:03 | 显示全部楼层
回复 1# zzf6870
   已解决。修改Binding file.rul 即可。把schematic 和 layout中器件的名字改成自己实际定义的即可
发表于 2016-7-16 13:24:33 | 显示全部楼层
回复 3# zzf6870
    请问你是去掉不要binding file 文件是吗?
GMT+8, 2025-12-16 23:47 , Processed in 0.014765 second(s), 5 queries , Gzip On, Redis On.
