在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
芯片精品文章合集(500篇!)    创芯人才网--重磅上线啦!
查看: 17971|回复: 16
[资料] 我有JPEG2000 encoder IP 和JPEG2000 decoder IP
发表于 2014-2-24 17:57:06 | 显示全部楼层 |阅读模式
我有JPEG2000 encoder IP 和JPEG2000 decoder IP,可以用于FPGA上也可用于asic上的。 是正规途径的IP核,能提供技术支持服务,并能确保您的项目顺利成功。
JPEG2000 encoder IP core的主要Features:
• Multichannel high-definition (HD) video standard
• Compliant with Digital Cinema Initiatives (DCI) recommendation
•  Compliant with International Organization for Standardisation  (ISO) or International Electro technical
Commision  (IEC) 15444-1: JPEG2000 Image Coding System
•  Integrated intellectual property (IP) core offering an Altera® FPGA solution for HD and DCI JPEG 2000 video
applications
•  Support for lossless and lossy compression schemes
•  Configurable output bit rate: 250 Mbps, 500 Mbps, 1Gbps, or  lossless
•  Full-frame encoding (no tiling)
•  Dynamically configurable encoder parameters, including:
- 5/3 or 9/7 wavelet filter, 0 to 6 levels
-Configurable tile size up to 1080p, 2K, and 4K
- Up to 12-bit precision per color component
- XYZ, RGB, YUV (4:4:4 or 4:2:2) color spaces with support for inverse color transform (ICT) or residual color transform (RCT)
- Configurable bit rate on a frame-by-frame basis with three selectable regulation modes
- Component-position-resolution-layer (CPRL) or layer-resolution-component-position (LRCP) progression order
- Specific quantization factor per subband
•  Fully synchronous design
 楼主| 发表于 2014-2-24 18:04:50 | 显示全部楼层
JPEG2000 decoder IP core的主要Features是如下:
  • Compliant with JPEG 2000 (ISO/IEC 15444-1)
  • Multi-channel interface
  • Compliant with DCI (Digital Cinema Initiatives) recommendation
  • Integrated Intellectual Property (IP) core for HD and DCI JPEG 2000
  • Single-FPGA solution for multi-channel:
    • DCI: 2K@24fps, 2K@48fps, 2K3D@24fps, 4K@24fps and 4K3D@24fps
    • HD: 720p30/60, 1080i, 1080p30/60
    • Custom frame sizes up to 4096x2160
    • Customizable input bit rate: up to 250Mbps / 500Mbps / 1Gbps / lossless
  • XYZ, RGB, YUV (4:4:4 or 4:2:2) color spaces with support for ICT/RCT color transform
  • Supported JPEG 2000 parameters:
    • Wavelet filters: 9/7 and 5/3, 0 to 6 decomposition levels
    • Full-frame decoding (no tiling)
    • Pixel depth: up to 12 bits per color sample
  • Fully autonomous decoder with automatic parameter extraction, minimal user intervention
详情请和我联系
发表于 2014-2-24 18:28:44 | 显示全部楼层
CAST公司的吧 呵呵
发表于 2014-2-24 18:30:03 | 显示全部楼层
直接说卖多少钱吧 省得给你站短了
 楼主| 发表于 2014-2-24 18:36:45 | 显示全部楼层
我们是WWAGO公司的(www.wwago-inc.com)。不是CAST公司的。
 楼主| 发表于 2014-2-24 18:37:53 | 显示全部楼层
我们是WWAGO 公司的,不是CAST公司
发表于 2014-2-25 09:50:40 | 显示全部楼层
是盗版吗?
发表于 2014-2-25 12:16:18 | 显示全部楼层
Is there source code
 楼主| 发表于 2014-2-25 12:39:57 | 显示全部楼层
源代码,正版的。
有技术支持,确保项目成功顺利
 楼主| 发表于 2014-3-11 18:29:17 | 显示全部楼层
GMT+8, 2024-5-11 02:02 , Processed in 0.036039 second(s), 10 queries , Gzip On, Redis On.
