查看: 39308|回复: 27
[求助] VCS后仿$setuphold提示
发表于 2012-6-20 10:05:41 | 显示全部楼层 |阅读模式
本人在用icc导出的.v和pt导出的sdf文件反标后仿的时候总是遇到$setuphold提示的违例:
"smic13g_neg.v",18853: Timing violation in tb_pb_Cal.pb_cal_test.weight_3_reg_9_
    $setuphold(posedge CK:5348, posedge RN:5303, limits: (176,-37) );
"smic13g_neg.v",18781: Timing violation in tb_pb_Cal.pb_cal_test.weight_3_reg_11_
    $setuphold(posedge CK:5362, posedge RN:5302, limits: (234,-52) );
"smic13g_neg.v",18781: Timing violation in tb_pb_Cal.pb_cal_test.weight_tmp_3_reg_11_
"smic13g_neg.v",18853: Timing violation in tb_pb_Cal.pb_cal_test.weight_tmp_3_reg_19_
    $setuphold(posedge CK:5362, posedge RN:5302, limits: (173,-36) );
"smic13g_neg.v",18781: Timing violation in tb_pb_Cal.pb_cal_test.weight_3_reg_13_
"smic13g_neg.v",18781: Timing violation in tb_pb_Cal.pb_cal_test.weight_3_reg_19_
"smic13g_neg.v",18853: Timing violation in tb_pb_Cal.pb_cal_test.weight_3_reg_18_
    $setuphold(posedge CK:5363, posedge RN:5302, limits: (173,-36) );
"smic13g_neg.v",18781: Timing violation intb_pb_Cal.pb_cal_test.weight_tmp_3a_reg_14_
    $setuphold(posedge CK:5375, posedge RN:5304, limits: (231,-52) );
"smic13g_neg.v",18781: Timing violation intb_pb_Cal.pb_cal_test.weight_tmp_3a_reg_10_
    $setuphold(posedge CK:5375, posedge RN:5303, limits: (231,-52) );
"smic13g_neg.v",18781: Timing violation intb_pb_Cal.pb_cal_test.weight_tmp_3a_reg_12_
"smic13g_neg.v",18781: Timing violation intb_pb_Cal.pb_cal_test.weight_tmp_3a_reg_11_
这个提示到底是setup 违例还是hold time违例呢,那个limits总是看不懂
这个case的icc和pt什马的都过了,但是一直有这个错误提示,vcs后仿总是失败。。。求大神指导阿。。。
 楼主| 发表于 2012-6-20 10:40:11 | 显示全部楼层
木人瓦,我看了下库里面的定义有那个一段儿:
`timescale 1ns/1ps
`celldefine
module DFFRX2 (Q, QN, D, CK, RN);
output Q, QN;
input  D, CK, RN;
reg NOTIFIER;
supply1 xSN;
  buf   XX0 (xRN, RN);
supply1 dSN;
wire dD;
wire dCK;
wire dRN;
  buf     IC (clk, dCK);
  udp_dff I0 (n0, dD, clk, dRN, dSN, NOTIFIER);
  and     I4 (flag, dRN, dSN);
  buf     I1 (Q, n0);
  not     I2 (QN, n0);
  specify
    specparam
    tplh$RN$Q  = 1.0,
    tphl$RN$Q  = 1.0,
    tplh$RN$QN  = 1.0,
    tphl$RN$QN  = 1.0,
    tplh$CK$Q        = 1.0,
    tphl$CK$Q        = 1.0,
    tplh$CK$QN        = 1.0,
    tphl$CK$QN        = 1.0,
    tsetup$D$CK        = 1.0,
    thold$D$CK        = 0.5,
    tsetup$RN$CK    = 1.0,
    thold$RN$CK    = 0.5,
    tminpwl$RN     = 1.0,
    tminpwl$CK    = 1.0,
    tminpwh$CK    = 1.0,
    tperiod$CK    = 1.0;
    if (flag)
      (posedge CK *> (Q +: D)) = (tplh$CK$Q,    tphl$CK$Q);
    if (flag)
      (posedge CK *> (QN -: D)) = (tplh$CK$QN,   tphl$CK$QN);
    $setuphold(posedge CK &&& (flag == 1), posedge D, tsetup$D$CK, thold$D$CK, NOTIFIER, , ,dCK,dD);
    $setuphold(posedge CK &&& (flag == 1), negedge D, tsetup$D$CK, thold$D$CK, NOTIFIER, , ,dCK,dD);
      (negedge RN *> (Q +: 1'b0)) = (tphl$RN$Q);
      (negedge RN *> (QN -: 1'b0)) = (tplh$RN$QN);
    $setuphold(posedge CK, posedge RN, tsetup$RN$CK, thold$RN$CK, NOTIFIER, , ,dCK,dRN);
    $width(negedge RN, tminpwl$RN, 0, NOTIFIER);
    $width(negedge CK &&& (flag == 1), tminpwl$CK, 0, NOTIFIER);
    $width(posedge CK &&& (flag == 1), tminpwh$CK, 0, NOTIFIER);
    $period(posedge CK &&& (flag == 1), tperiod$CK, NOTIFIER);
   endspecify
endmodule // DFFRX2
`endcelldefine
这个库里面的关于CLK和RN的$setuphold的notifier和一般的setuphold time定义貌似不太一样,我改了下testbench就搞定了,貌似是RN保持的时间不足
发表于 2012-8-3 10:31:15 | 显示全部楼层
以第一行为例:
5348-5303=47<176,setup也就是recovery满足,
5303-5348=-47,绝对值超过了-37,因此hold不满足。
原因:要么pt没有分析到,要么电路上这个地方是false path。
点评
cxa
RN在CK之前出现上升沿,setup 47,小于176,不满足  发表于 2023-4-4 10:20
发表于 2012-10-14 21:16:43 | 显示全部楼层
学习了,多谢
发表于 2012-10-15 20:39:20 | 显示全部楼层
学习,路过。
发表于 2012-10-24 23:41:31 | 显示全部楼层
这个解释怎么感觉有点和看文档的不同呢?
发表于 2012-12-6 17:00:05 | 显示全部楼层
回复 3# bigbird
   这个可以看到data_event(RN)是在reference_event(CK)的前面,这个应该是建立时间吧,建立时间只有47<最小建立时间176,因此不满足建立时间的条件。这里跟保持时间没关系吧
下面的是$setuphold的定义,引自verilog2001的标准:
$setuphold ( reference_event , data_event , timing_check_limit ,  timing_check_limit
[ , [ notify_reg ] [ , [ stamptime_condition ] [ , [ checktime_condition ]
[ , [ delayed_reference ] [ , [ delayed_data ] ] ] ] ] ] )
发表于 2014-9-16 13:46:41 | 显示全部楼层
3楼正解
发表于 2014-11-30 11:31:57 | 显示全部楼层
楼主,看了这个标准单元的定义:
其中CK,D,RN 端口 ,和dD,dCK,xRN 怎么连接的,没有看到相关语句。一般不是wire类型的需要配合assign语句赋值么?
难道是跟这句有关:
可是看语句解释,没有看到相关解释?
发表于 2014-12-1 19:33:39 | 显示全部楼层
3楼正解
GMT+8, 2025-12-9 03:08 , Processed in 0.018872 second(s), 6 queries , Gzip On, Redis On.
