查看: 4622|回复: 16
[资料] Mentor Graphics VHDL Reference Manual
发表于 2011-9-17 15:14:23 | 显示全部楼层 |阅读模式
TABLE OF CONTENTS
  About This Manual        xv
  Section 1
     Lexical Elements        1-1
        Definition of Lexical Elements                                                     1-3
        Character Set        1-5
        Replacement Characters                                                             1-6
        Identifiers        1-8
        Reserved Words        1-9
        Comments        1-15
        Literals        1-15
          Numeric Literals        1-15
           Character Literals                                                             1-18
           String Literals        1-19
           Character and String Literal Differences                                       1-20
           Bit String Literals                                                            1-20
        Separators and Delimiters                                                         1-21
           Separators        1-21
           Delimiters        1-22
Section 2
     Expressions        2-1
        Definition of Expressions                                                          2-3
           General Expression Rules                                                        2-4
        Operands (Primaries)                                                               2-6
          Names        2-6
           Literal        2-7
           Aggregates        2-8
           Function Calls        2-10
           Qualified Expressions                                                          2-10
           Type Conversions                                                               2-12
Mentor Graphics VHDL Reference Manual, July 1994                                            iii
TABLE OF CONTENTS                       [continued]
  Section 2    Expressions   [continued]
          Allocators        2-13
        VHDL Predefined Operators                                                       2-16
          Important Notes About Operators                                               2-17
          Miscellaneous Operators                                                       2-18
          Multiplying Operators                                                         2-20
          Sign        2-22
          Adding Operators                                                              2-23
          Shift Operators                                                               2-28
          Relational Operators                                                          2-28
             Predefined Equality and Inequality Operators                               2-29
             Predefined Ordering Operators                                              2-30
          Logical Operators                                                             2-31
        Static Expressions                                                              2-32
       Universal Expressions                                                            2-36
  Section 3
     Naming, Scope, and Visibility                                                       3-1
       Naming        3-3
          Simple Names        3-4
          Selected Names        3-4
          Indexed Names        3-8
          Slice Names        3-9
          Attribute Names                                                               3-10
        Scope and Visibility                                                            3-12
          Declarative Region                                                            3-12
          Scope        3-13
             Scope Rules        3-15
          Visibility        3-16
             Visibility Rules                                                           3-17
             use_clause        3-22
          Overload Resolution                                                           3-24
Section 11
Signals    11-1
Signal Concepts    11-4
Drivers    11-4
Guarded Signals    11-5
disconnection_specification    11-8
Multiple Drivers and Resolution Functions   11-10
signal_declaration   11-14
Default Expression   11-15
Signal Assignments   11-16
Sequential Signal Assignments   11-16
Concurrent Signal Assignments   11-17
Delay Concepts   11-19
Delta Delay   11-20
VHDL_reference_manual.pdf (1.17 MB , 下载次数: 113 )
发表于 2011-9-17 20:13:08 | 显示全部楼层
非常感谢
发表于 2011-9-17 23:21:46 | 显示全部楼层
很好,急需
发表于 2011-9-18 20:55:44 | 显示全部楼层
感谢楼主的共享
发表于 2011-9-19 09:30:11 | 显示全部楼层
顶顶 呵呵....
发表于 2011-9-19 21:47:24 | 显示全部楼层
很好,谢谢
发表于 2011-9-20 01:31:14 | 显示全部楼层
回复 1# pontiff
thanks for good reference material share
 楼主| 发表于 2011-9-30 08:32:36 | 显示全部楼层
感觉还是看EDA厂家的手册之类比较好,学习一下良好的规范
发表于 2011-10-5 21:44:39 | 显示全部楼层
thanks
发表于 2011-10-6 10:25:55 | 显示全部楼层
回复 1# pontiff
    thank you
GMT+8, 2025-12-7 18:39 , Processed in 0.028771 second(s), 7 queries , Gzip On, Redis On.
