查看: 7659|回复: 24
[原创] (Nyquist) ADC Spectrum Analysis
发表于 2011-1-10 06:51:59 | 显示全部楼层 |阅读模式
I summarized some notes in PowerPoint, concerning the use of SpiceExplorer to analyze the SNR/SNDR of Nyquist ADC.
A behavioral 8-bit Nyquist ADC was used to examine the effect of various parameters / settings in FFT/DFT analysis tools of SpiceExplorer.
Three netlist files are attached in the PowerPoint file.
They are:
  • The original netlist from Jacob Baker.
  • The moderated netlist able to pass WinSpice checks.
  • The migrated netlist able to run with HSPICE simulator.
I then used the migrated netlist to check how FFT/DFT analysis tool should be used in SpiceExplorer.
All the settings were recorded, so that readers can follow and understand.
I personally think this document serves as a valid tutorial to understand SpiceExplorer FFT/DFT analysis tool.
I intended to port the transient analysis result to MATLAB and wanted to check if MATLAB would result in the same result.
After the exploration of the FFT/DFT analysis tool of SpiceExplorer, my perosnal conclusion is MATLAB double-check does not seem necessary.
Spectrum Analysis Tools.zip
528.61 KB, 下载次数: 223 , 下载积分: 资产 -2 信元, 下载支出 2 信元
ADC Spectrum Analysis PowerPoint
发表于 2011-1-10 07:54:37 | 显示全部楼层
谢谢楼主的分享
 楼主| 发表于 2011-1-10 09:42:52 | 显示全部楼层
懇求各位看倌給一些意見
內容有何可改進或加強之處
XieXie!
发表于 2011-1-10 18:09:42 | 显示全部楼层
不错! Thanks
发表于 2011-1-10 22:26:23 | 显示全部楼层
谢谢楼主的分享!
发表于 2011-1-10 22:48:42 | 显示全部楼层
thanks
发表于 2011-1-11 22:18:05 | 显示全部楼层
kankan,xiexie
发表于 2011-1-13 13:25:26 | 显示全部楼层
thanks a lot
发表于 2011-1-13 19:46:08 | 显示全部楼层
看看,学习学习
发表于 2011-1-20 00:28:49 | 显示全部楼层
好资料,感谢共享!!!!
GMT+8, 2025-11-4 07:31 , Processed in 0.022702 second(s), 6 queries , Gzip On, Redis On.
