在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 12074|回复: 26
[资料] 【楊致遠弟弟的phd論文】DESIGN OF HIGH-SPEED SERIAL LINK IN CMOS
发表于 2010-12-26 06:37:07 | 显示全部楼层 |阅读模式
現任UCLA的Professor (http://www.ee.ucla.edu/~ckygroup/)
Abstract
Demand for bandwidth in serial links has been increasing as the communications
industry demand higher quantity and quality of information. Whereas traditional gigabit
per second links has been in bipolar or GaAs, this research aims to push the use of CMOS
process technology in such links. Intrinsic gate speed limitations are overcome by
parallelizing the data. The on-chip frequency is maintained at a fraction (1/16) of the offchip
data rate. Clocks with carefully controlled phases tapped from a local ring oscillator
are driven to a bank of input samplers to convert the serial bit stream into parallel data.
Similarly, the overlap of multiple-phased clocks are used to synchronize the multiplexing
of the parallel data onto the transmission line. To perform clock/data recovery, data is
further oversampled with finer phase separation and passed to digital logic. The digital
logic operates upon the samples to detect transitions in the bit stream to track the bit
boundaries. This tracking can operate at the cycle rate of the digital logic allowing
robustness to systematic phase noise. The challenge lies in the capturing of the high
frequency data stream and generating low jitter, accurately spaced clock edges. A test chip
is built demonstrating the transmission and recovery of a 4.0-Gb/s bit streams with < 10-14
bit-error rate using a 3x oversampled system in a 0.5-mm MOSIS CMOS process.
(1998.12)[Chil-Kong Ken Yang]DESIGN OF HIGH-SPEED SERIAL LINK IN CMOS.pdf (2.04 MB, 下载次数: 237 )
发表于 2010-12-26 09:51:22 | 显示全部楼层
下来看看,谢谢。
头像被屏蔽
发表于 2010-12-26 11:30:36 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-12-26 20:49:47 | 显示全部楼层
题目太二了
发表于 2010-12-27 09:56:31 | 显示全部楼层
gsdfgsdfgsdf
发表于 2010-12-28 18:53:10 | 显示全部楼层
看起来很久以前的论文了。
发表于 2011-1-6 14:03:19 | 显示全部楼层
dddddddddddddddddd
发表于 2011-1-19 04:19:20 | 显示全部楼层
goodddddddddd
发表于 2011-1-23 11:03:16 | 显示全部楼层
not bad!!!!!
发表于 2011-1-23 13:37:29 | 显示全部楼层
多谢楼主
GMT+8, 2025-7-1 00:53 , Processed in 0.031281 second(s), 10 queries , Gzip On, MemCached On.
