查看: 69304|回复: 92
Synopsys Tools安装以及License设定
发表于 2009-10-10 11:32:49 | 显示全部楼层 |阅读模式
按照网上大侠的指点,我在RHAS5上安装了Leda2008.06,syn-vC-2009.06以及VCS2008.12和ICC2007.06
使用EFA LicGen 04b和SSS feature KeyGen产生的license,其中使用的synopsys.scr文件就是网上的,大约40k大小的那个。
运行license daemon,license应该起来了,但是,运行相关的指令的时候,还是说没有match的license,详细信息如下:
运行了License以后,相应的log file的最后部分如下:
19:17:11 (lmgrd) snpslmd using TCP-port 44212
19:17:11 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd
chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd
  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  sn
psOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
19:17:12 (snpslmd) -------------------------------------------------------------
19:17:12 (snpslmd) Checking the integrity of the license file....
19:17:12 (snpslmd) Valid SSS feature found.
19:17:12 (snpslmd) The feature is needed to enable the other keys in your licens
e file.
我想License还是应该起来了吧?
但是我运行leda &,dv &, dc &, 以及icc_shell &等,还是说没有license,error信息如下:
[ybhsu@localhost ~]$ leda &
[1] 9799
                 Leda (TM) Design & Constraint Checker
           Version B-2008.06 for linux -- October 9, 2009
              Copyright (c) 2000-2008 by Synopsys, Inc.
                         ALL RIGHTS RESERVED
This software and  the associated documentation  are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
[ybhsu@localhost ~]$ Feature     : leda_checker
License path: /eda/synopsys/license/synopsys.dat
FLEXlm error: The license key and data for the feature do not match.
This usually happens when a license file has been altered.
System error: no error
License checkout failed
[ybhsu@localhost ~]$ dc &
[1] 9821
[ybhsu@localhost ~]$ Fatal: Design Compiler is not enabled. (DCSH-1)
[1]    Exit 255                      dc_shell
[ybhsu@localhost ~]$ dv &
[1] 9847
[ybhsu@localhost ~]$ Unable to obtain feature 'Design-Vision ' because:
Error: Software is not licensed for this machine. (SEC-10)
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
[1]    Exit 255                      design_vision
[ybhsu@localhost ~]$ icc_shell &
[1] 10005
[ybhsu@localhost ~]$ Fatal: Galaxy-Common+Galaxy-ICC is not enabled. (DCSH-1)
Exit IC Compiler!
所有的Error表明,还是没有license,这大概是怎么回事?所有做license的过程都是按照网上大侠的指点进行的。
如何正确的制作这个license啊?急!!在这里先谢了。
此时重新检查log file,在log file的最后,多了一些提示如下:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  e
verest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sig
macd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  s
19:17:12 (snpslmd) ------------------------------------------------------------------
19:17:12 (snpslmd) The feature is needed to enable the other keys in your license file.
19:27:22 (snpslmd) TCP_NODELAY NOT enabled
19:27:22 (snpslmd) OUT: "leda_checker" ybhsu@localhost.localdomain
19:27:22 (snpslmd) UNSUPPORTED: "leda_specifier" (PORT_AT_HOST_PLUS   ) ybhsu@localhost.local
domain  (License server system does not support this feature. (-18,327))
19:27:22 (snpslmd) OUT: "provhdl_checker" ybhsu@localhost.localdomain
19:27:22 (snpslmd) UNSUPPORTED: "provhdl_specifier" (PORT_AT_HOST_PLUS   ) ybhsu@localhost.lo
caldomain  (License server system does not support this feature. (-18,327))
19:27:22 (snpslmd) UNSUPPORTED: "proverilog_checker" (PORT_AT_HOST_PLUS   ) ybhsu@localhost.l
ocaldomain  (License server system does not support this feature. (-18,327))
19:27:22 (snpslmd) UNSUPPORTED: "proverilog_specifier" (PORT_AT_HOST_PLUS   ) ybhsu@localhost
.localdomain  (License server system does not support this feature. (-18,327))
19:27:22 (snpslmd) IN: "provhdl_checker" ybhsu@localhost.localdomain
19:27:22 (snpslmd) IN: "leda_checker" ybhsu@localhost.localdomain
19:28:09 (snpslmd) OUT: "Design-Vision" ybhsu@localhost.localdomain
19:28:09 (snpslmd) OUT: "Design-Analyzer" ybhsu@localhost.localdomain
19:28:09 (snpslmd) IN: "Design-Vision" ybhsu@localhost.localdomain
19:28:09 (snpslmd) IN: "Design-Analyzer" ybhsu@localhost.localdomain
这是为啥?那位大侠能帮忙指导一下!!!
发表于 2009-11-24 10:25:50 | 显示全部楼层
我DC设计对了,但ICC设定不对,ICC2009的
发表于 2009-11-24 14:10:38 | 显示全部楼层
学习了!
发表于 2009-11-24 16:12:49 | 显示全部楼层
這一段就說明答案囉...
這個license server 只提供以下features.....
小弟怎看就是找不到你要的那幾個features.....
參考之....
 楼主| 发表于 2009-11-30 20:26:44 | 显示全部楼层
已经安装成功!!!
发表于 2009-12-8 23:35:12 | 显示全部楼层
ybhsu2008   你好  我也碰到了同样的问题  可否告知如何解决的  谢谢!
发表于 2009-12-9 10:23:53 | 显示全部楼层
5# ybhsu2008
不要有问题就提,解决了就一声不吭呀.
发表于 2009-12-15 11:14:58 | 显示全部楼层
需要有SSS 这个feature的
发表于 2009-12-16 13:17:12 | 显示全部楼层
4# toxicly
这段文字说明的是flexm支持的eda工具厂商的工程名. snpslmd就是指的synopsys使用的flexm
发表于 2009-12-16 13:21:20 | 显示全部楼层
GMT+8, 2025-11-9 15:58 , Processed in 0.023536 second(s), 5 queries , Gzip On, Redis On.
