在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 19034|回复: 99
【2008 Springer】Timing Optimization Through Clock Skew Scheduling
发表于 2009-7-11 04:05:02 | 显示全部楼层 |阅读模式
by   Ivan S. Kourtev
              Ivan S. Kourtev                            (Author)
            › Visit Amazon's Ivan S. Kourtev Page
        Find all the books, read about the author, and more.
         See search results for this author
        Are you an author?         Learn about Author Central
(Author), Baris Taskin (Author), Eby G. Friedman (Author)
                Key Phrases: clock skew scheduling, skew scheduling problem, local data path, Springer Science, Business Media, Timing Properties of Synchronous Systems (more...)
Editorial Reviews        Product Description
Thefocus of this book is on timing analysis and optimization techniquesfor circuits with level-sensitive memory elements (registers).Level-sensitive registers are becoming significantly more popular inpractice as integrated circuit densities are increasing and the'performance-per-power' metric for integrated circuits becomes a keyissue. Therefore, techniques for understanding level-sensitive basedcircuits and for optimizing the performance of such circuits areincreasingly important. The book includes the following major topics inthe timing analysis and optimization of level-sensitive circuits. Alinear programming (LP) formulation applicable to the timing analysisof large scale circuits. The formulation uses a variation of the big Mmethod - called the modified big M method - to transform the non-linearconstraints in the problem formulation into solvable linearconstraints.This LP formulation is computationally efficient anddemonstrates significant circuit performance improvement. By makingmaximum use of cycle stealing, operation at a higher clock frequency(reduced clock period) is possible. A delay insertion methodology thatimproves the efficiency of clock skew scheduling in level-sensitivecircuits. It is shown that re-convergent paths limit the improvement ofcircuit performance that can be achieved through clock skew scheduling.The described delay insertion method mitigates the limitations cause byre-convergent data paths and improves the results of timingoptimization (for increased clock frequency). A summary of circuitpartitioning, placement and synchronization methodologies that enablesthe implementation of high speed, low power circuits synchronized withultra modern resonant clocking technology (such as travelingoscillators/waves).The described framework includes the particularcircuit partitioning and placement methodologies that permit thehierarchical application of non-zero clock skew system timing inresonant clocking based circuits. A framework for and results fromimplementing the described timing optimization algorithms in a parallelcomputing environment. As multi-core microprocessors becomecommonplace, computationally intense algorithms can benefit greatly byexploiting this available parallelism. The framework uses a heuristicapproach to generate circuit partition and solve them independently onprocessors/computers working on parallel. This is one of the first suchapplications of explicit parallelism in Electronic Design Automation(EDA), and, will be of great interest to practicing EDA engineers.
Timing Optimization Through Clock Skew Scheduling.pdf
3.42 MB, 下载次数: 971 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-11 05:53:50 | 显示全部楼层
Thanks a lot.
发表于 2009-7-11 07:31:44 | 显示全部楼层
Thanks a lot !!!!!!!!!!!!!
发表于 2009-7-11 09:00:06 | 显示全部楼层
:victory::victory:
发表于 2009-7-11 09:38:23 | 显示全部楼层
66
Thanks for sharing ..........
发表于 2009-7-11 13:25:21 | 显示全部楼层
sdfgsdfgdsfgdfgdfgdsfgsdfgsdfgdf
发表于 2009-7-11 16:25:56 | 显示全部楼层
xiexie
发表于 2009-7-13 08:46:23 | 显示全部楼层
xie xie
发表于 2009-7-13 09:12:01 | 显示全部楼层
Thanks!!!
发表于 2009-7-13 13:09:03 | 显示全部楼层
tks a lot,拜读
GMT+8, 2024-4-26 09:08 , Processed in 0.031049 second(s), 8 queries , Gzip On, Redis On.
