查看: 4791|回复: 10
安装ADS2016时license通过还是有错。
发表于 2018-8-7 10:54:27 | 显示全部楼层 |阅读模式
QQ浏览器截图20180807105148.png   有遇到类似情况的吗。
 楼主| 发表于 2018-8-7 13:43:04 | 显示全部楼层
HPEESOF_LIC_DIR= path not found.......fail
在Diagnose里面看到HPEESOF_LIC_DIR= path not found.......fail,然后我设置了一下环境变量,可是还是不行
发表于 2018-8-7 15:54:31 | 显示全部楼层
You need set patch where your license is stored in environmental variables.
发表于 2018-8-7 16:01:43 | 显示全部楼层
You need create new variable value in environmental variables
发表于 2018-8-7 16:03:51 | 显示全部楼层
Or set license patch in LMtool in license file. LM tool from Flexnet
 楼主| 发表于 2018-8-8 17:49:14 | 显示全部楼层
回复 4# reptilian77
   I have set a new environment variable and pointed at the license,but it's not work. so I installed ADS.2017.
发表于 2018-8-8 19:52:48 | 显示全部楼层
New version of ADS2018 is released.
发表于 2018-8-8 23:25:17 | 显示全部楼层
这个错误是软件发现了许可证是假的,应该是破解不到位,再重新按步骤试试,ADS破解一般不太复杂的
 楼主| 发表于 2018-8-9 09:25:37 | 显示全部楼层
回复 7# reptilian77
   OK, fine! thank you
发表于 2018-8-9 10:40:58 | 显示全部楼层
看一看,谢谢.
GMT+8, 2025-9-11 11:50 , Processed in 0.017621 second(s), 4 queries , Gzip On, Redis On.
