查看: 3124|回复: 3
[原创] DW_ocb needs AMBA OCB Designware
发表于 2017-10-31 10:51:57 | 显示全部楼层 |阅读模式
Hi I found the below something which is it may be made by something tool.
Would you please let me know what kind tool is supporting to make the below file?
// Release version :  2.01a
// File Version     :        $Revision: #24 $
// Revision: $Id: //dwh/DW_ocb/DW_axi_x2p/amba_dev/src/DW_axi_x2p_cc_constants.v#24 $
// Description : This file contains all configuration parameters.
// AXI INTERFACE SETUP
// Name:         X2P_AXI_INTERFACE_TYPE
// Default:      AXI3
// Values:       AXI3 (0), AXI4 (1)
// Enabled:      [<functionof> %item]
发表于 2017-10-31 15:07:43 | 显示全部楼层
回复 1# h9f3
   coreTool is your need. However, you should need xxx.run source file and license from synopsys.
 楼主| 发表于 2017-10-31 22:44:47 | 显示全部楼层
&#54924;&#49888; 2 # woai2020
    &#51228;&#48156;, coreConsultant&#51032; Qos &#44592;&#45733; &#48708;&#54876;&#49457;&#54868;
 楼主| 发表于 2017-10-31 22:49:27 | 显示全部楼层
[&#44204;&#51201;] &#45824;&#45813; h9f3
   coreTool&#51060; &#54596;&#50836;&#54633;&#45768;&#45796;. &#44536;&#47084;&#45208; xxx.run &#49548;&#49828; &#54028;&#51068;&#44284; &#46972;&#51060;&#49468;&#49828;&#44032; &#54596;&#50836;&#54633;&#45768;&#45796; ...
woai2020 2017-10-31 15:07&#50640; &#44172;&#49884; &#46120; [/ quote]
   I need QoS Option, how do I get the source license?what is the source license? Are those different things?
GMT+8, 2025-11-10 09:00 , Processed in 0.021999 second(s), 3 queries , Gzip On, Redis On.
