查看: 3179|回复: 3
[求助] 求助dc加载工艺库
发表于 2017-5-21 14:44:21 | 显示全部楼层 |阅读模式
我在工作目录下创建了synopsys_dc.setup,只想加载TSMC工艺库,但每次运行dc的时候都会加载Synplify2015下的工艺文件,怎么才能让
dc只加载tsmc呢?
  1. Initializing...
  2. ==================================================================
  3. Library Settings:
  4. search_path:             . /opt/Synopsys/Synplify2015/libraries/syn /opt/Synopsys/Synplify2015/minpower/syn /opt/Synopsys/Synplify2015/dw/syn_ver /opt/Synopsys/Synplify2015/dw/sim_ver /opt/Foundary_Library/TSMC90/aci/sc-x/synopsys /opt/Foundary_Library/TSMC90/aci/sc-x/synopsys /opt/Foundary_Library/TSMC90/aci/sc-x/symbols/synopsys
  5. link_library:            * slow.db
  6. target_library:          slow.db
  7. symbol_library:          tsmc090.sdb
  8. ==================================================================
  9. I am ready...
  10. Initializing gui preferences from file  /home/IC/.synopsys_dv_prefs.tcl
  11. read_file -format verilog {/home/IC/project/cpu_test/v/risc_cpu_new.v}
  12. Loading db file '/opt/Foundary_Library/TSMC90/aci/sc-x/synopsys/slow.db'
  13. Loading db file '/opt/Synopsys/Synplify2015/libraries/syn/gtech.db'
  14. Loading db file '/opt/Synopsys/Synplify2015/libraries/syn/standard.sldb'
复制代码
发表于 2017-5-22 13:09:17 | 显示全部楼层
您的search path 包含 synplify2015/.........
把所有synplify2015的path 移除
加上design compiler的path
Ex: /opt/Synopsys/F-2011.09-SP2/libraries/syn
這樣應該就可以了
 楼主| 发表于 2017-5-22 20:14:38 | 显示全部楼层
回复 2# wythelin
我在search path里只写了tsmc的path,可结果还是加载synplify2015目录。。。
发表于 2017-5-23 13:05:45 | 显示全部楼层
回复 3# wangyangcha
應該不會這樣,library 只會在search path 裡面找你之前post 的log,很明顯是找到synplify的path
方便的話,可以post log file,比較好釐清
GMT+8, 2025-7-5 19:10 , Processed in 0.016991 second(s), 7 queries , Gzip On, MemCached On.
