查看: 6990|回复: 3
[原创] Vivado下实例化HDL代码
发表于 2017-5-18 20:20:29 | 显示全部楼层 |阅读模式
刚开始用Vivado,发现找不到ISE中生成实例化模板的选型了,只能自己写。在网上搜索了一下,几乎没有给出答案,最终在Xilinx官网找到了解决方案:
Install the Designutils app in the Tcl Appstore (Tools -> Xilinx Tcl Store) if it has not been previously installed.
The module should be set as top-level.
When it is elaborated or synthesized:
  • Run "xilinx::designutils::write_template" to create a stub, template or testbench.
  • Run "xilinx::designutils::write_template -usage" for usage information.
详见:AR#58023。
官网给出的是Vivado 2014.1,经测试,之后版本都可用,只是不方便的是使用时要把被例化模块设置为顶层模块。
发表于 2017-8-31 23:16:04 | 显示全部楼层
回复 1# Zrh
    thanks for sharing
发表于 2018-3-4 22:45:14 | 显示全部楼层
回复 2# ibubapa
    thanks for sharing
发表于 2022-3-2 03:34:26 | 显示全部楼层
thanks alot.
very helpful
GMT+8, 2025-12-13 02:51 , Processed in 0.012724 second(s), 3 queries , Gzip On, Redis On.
