查看: 8375|回复: 24
[资料] H.264 AVC 和 H.265 HEVC decoder IP 核
发表于 2016-12-18 12:18:36 | 显示全部楼层 |阅读模式
WWAGO公司提供以下H.264/AVC ,H.265/HEVC的IP核,另外提供相应的platform solution。
(1) H.264/AVC HD decoder
(2) H.264/AVC 4K decoder
(3) H.265/HEVC HD decoder
(4) H.265/HEVC 4K decoder
给大家分享一下,有需要的可以联系:sales@wwago-inc.com
> H.264/AVC HD decoder : 支持下面的spec
- Standard: H.264/MPEG-4 Part 10 (ISO/IEC 14496-10 & ITU-T H.264)
- Profiles:  Constrained Baseline, Main & High proöles
- Video Resolutions: Up to 1920 x 1080
- Frame Rate:  Up to 60 fps
- Bit rate:  CABAC Bitrate: 40 Mbps. Scalable to 80 Mbps / CAVLC Bitrate: 80 Mbps. Scalable to 160 Mbps
- Chroma Format: Monochrome, 4:2:0 & 4:2:2
- Precision:   Bit depths from 8 to 10
- Input Format:  Elementary or Transport stream
- Output Format:  Decoded pictures in frame buffer. Optional serial output with embedded sync information
- Latency:   Ultra low latency of 10 ms
- Codec Flavors:   AVC – Ultra, H.264 4K, XAVC
> H.264/AVC 4k decoder : 支持下面的spec
- Video Resolutions: Up to 4096 x 2160
- Bit rate:   CABAC Bitrate: Up to 160 Mbps / CAVLC Bitrate: Up to 320 Mbps
- Precision: Bit depths from 8 to 10. Scalable to 12
- Codec Flavors: AVC – Ultra, XAVC 4K, XAVC 4K Intra
> H.265/HEVC HD decoder : 支持下面的spec
- Standard: HEVC/H.265 ( ISO/ IEC 23008-2 and ITU-T H.265 )
- Profiles:  Main, Main10, Main 12, Main 10 4:2:2 and Main 12 4:2:2
- Frame Rate:  60 fps
- Bit rate:  75 Mbps. Scalable to 150 Mbps
- Precision:  Bit depths from 8 to 12
- Latency:  As low as a few microseconds
> H.265/HEVC 4K decoder : 支持下面的spec
 楼主| 发表于 2016-12-18 12:25:20 | 显示全部楼层
文档资料如下,有需要的联系:sales@wwago-inc.com
WWAGO H.264 HD Decoder.pdf (246 KB , 下载次数: 63 )
WWAGO H.264 4K Decoder.pdf (216.8 KB , 下载次数: 47 )
WWAGO H.265_HEVC HD Decoder.pdf (179.1 KB , 下载次数: 52 )
WWAGO H.265_HEVC 4K Decoder.pdf (201.66 KB , 下载次数: 76 )
发表于 2016-12-19 09:29:23 | 显示全部楼层
回复 1# 111_ZH
能否移植到XILINX ZYNQ并连接到AXI4总线?有报价单吗?
发表于 2016-12-21 12:13:50 | 显示全部楼层
谢谢分享!
发表于 2016-12-22 09:13:13 | 显示全部楼层
回复 2# 111_ZH
    thanks for sharing
发表于 2016-12-23 10:45:51 | 显示全部楼层
只有decoder?
 楼主| 发表于 2017-2-13 14:52:54 | 显示全部楼层
回复 3# goalyoung
   可以用在ZYNQ7000
发表于 2017-2-13 22:58:00 | 显示全部楼层
Look look
发表于 2017-2-15 18:49:59 | 显示全部楼层
THANKS FOR SHARING
发表于 2017-2-16 08:16:05 | 显示全部楼层
谢谢分享
GMT+8, 2025-11-12 23:11 , Processed in 2.369372 second(s), 6 queries , Gzip On, Redis On.
