楼主: jithinsmmb
[资料] << Galaxy common Galaxy ICC not enabled>> Why this error?
 楼主| 发表于 2016-1-30 20:52:12 | 显示全部楼层
I cant find Galaxy common and Galaxy ICC feature in my license.
Can anyone help me to solve this.
may be my synopsys.src problem
发表于 2016-1-30 22:14:58 | 显示全部楼层
Synopsys.zip (10.78 KB , 下载次数: 80 )
use this
 楼主| 发表于 2016-1-31 01:19:37 | 显示全部楼层
回复 12# qfliuyang
Not working.
Check that src , that doesn't contain any Galaxy common , Galaxy ICC  Features.
 楼主| 发表于 2016-1-31 01:21:38 | 显示全部楼层
回复 12# qfliuyang
Can you share any other ICC crack, with valid .src file for SCL 10.9.3
Thanks for your help.
发表于 2016-1-31 13:12:03 | 显示全部楼层
use this
synopsys_license_gen.zip (1.28 MB , 下载次数: 70 )
 楼主| 发表于 2016-1-31 13:43:07 | 显示全部楼层
回复 15# qfliuyang
License contain 2 categories , first section is package and second section is features.
In your src file The GALAXY-ICC and GALAXY Common are found in packages.
You cant find GALAXY-ICC and GALAXY Common in features .
发表于 2016-1-31 20:09:35 | 显示全部楼层
回复 16# jithinsmmb
   you should study the src/license file's syntex more carefully.
 楼主| 发表于 2016-2-1 12:57:55 | 显示全部楼层
回复 17# qfliuyang
   Can you share a working SCL version and corresponding IC compiler version here.
So I can go without any problems.
thanks sir.
发表于 2016-2-1 15:45:46 | 显示全部楼层
回复 8# jithinsmmb
I can't access this link.
 楼主| 发表于 2016-2-1 16:35:31 | 显示全部楼层
Reply 19 # daviehj
Can you Share a Working SCL Version and Corresponding IC Compiler Version here.
my [attach] 644777 [/ attach]
lmgrd.zip
12.03 KB, 下载次数: 32 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-11-7 04:22 , Processed in 0.022694 second(s), 4 queries , Gzip On, Redis On.
