查看: 16076|回复: 6
[求助] DC的时候报错
发表于 2014-7-22 09:39:30 | 显示全部楼层 |阅读模式
DC的时候报了如下error:
Error: extra positional option '_sel9' (CMD-012)
Error: extra positional option '_sel10' (CMD-012)
Error: extra positional option '_sel13' (CMD-012)
Error: extra positional option '_sel14' (CMD-012)
Error: extra positional option '_sel16' (CMD-012)
Error: extra positional option '_sel17' (CMD-012)
请问是什么意思?怎么消除?
多谢啦!
发表于 2014-7-22 16:54:38 | 显示全部楼层
This is related to you script. I guess you tried to get some ports using get_ports for example. Enough positional arguments have been passed to the command.
You shoudl verify that the option given is not a misspelled dash option. If a list is provided directly instead of as a variable, ensure it is enclosed by curly braces or double quotation marks.
It would be helpful if you can provide some of your scripts.
 楼主| 发表于 2014-7-23 10:34:29 | 显示全部楼层
回复 2# lvguang
    多谢!我先检查一下脚本吧,如果解决不了再麻烦您给看一下~
 楼主| 发表于 2014-7-23 17:15:26 | 显示全部楼层
回复 2# lvguang
    问题解决了,非常感谢!
发表于 2014-7-24 20:54:26 | 显示全部楼层
回复 4# linghuqiubai
   能否介绍下如何解决的?
 楼主| 发表于 2014-7-24 22:07:51 | 显示全部楼层
回复 5# lvguang
   大概就是按2楼说的,该括括号的地方全都廓上括号,莫名其妙就解决了……汗!
发表于 2014-7-25 00:15:30 | 显示全部楼层
回复 6# linghuqiubai
Cool
GMT+8, 2025-7-7 10:49 , Processed in 0.023581 second(s), 9 queries , Gzip On, MemCached On.
