返回列表 发新帖
楼主: lvdong19881008
[讨论] 有关毛刺的问题
发表于 2014-6-26 14:51:25 | 显示全部楼层
端口滤波就能解决
 楼主| 发表于 2014-6-26 22:15:10 | 显示全部楼层
回复 20# wh1105
   这样理论上应该可以解决,但是这样改是不是代码改动的地方比较大    谢谢 参与回复
 楼主| 发表于 2014-6-26 22:18:00 | 显示全部楼层
回复 21# tianrongcai
   端口指的是哪?你的意思是加滤波电容来解决毛刺?书上提到过这种方法,但是在这怎么用? 有没有必要?
发表于 2014-6-27 00:56:57 | 显示全部楼层
回复 22# lvdong19881008
That's right. The signals across the different clock domain is the designer guarantee that can work correctly.So you must to modify the code. The gray code is the general purpose method to do the signal across two different
clock domain. I hope it can help your reference.
GMT+8, 2025-5-31 03:08 , Processed in 0.015776 second(s), 7 queries , Gzip On, MemCached On.
