查看: 5849|回复: 6
[求助] 为什么不能产生网表文件,SDF,SDC文件?
发表于 2014-5-16 18:59:25 | 显示全部楼层 |阅读模式
我用 write -format verilog -hierarchy -output file.v       write_sdf  -version 2.1 /home/pro/syn/sdf/file.sdf
       write_sdc  /home/pro/sdc/file.sdc
命令无法产生网表和SDF SDC 文件,顺便,产生.db文件干吗用?
有高手清楚的话不吝指教哈~谢谢了哈~===========================================
我用 write -format verilog -hierarchy -output file.v       write_sdf  -version 2.1 /home/project/syn/sdf/file.sdf
       write_sdc  /home/project/sdc/file.sdc
有高手清楚的话不吝指教哈~谢谢了哈~
主要问题如下;
warning: can't find the design PS_IBUF...
warning: can't find the design PS_OBUF...
(这两个buffer是设计代码里在输入输出端口上加的buffer)
warning: design 'design_core' has '2' unresolved references...
第二个疑问是;log里的提示。。。
linking design ‘design_core'
using the following design and libraries...
design_core             /home/project/syn/src/design_core.db
我搞不懂的是我的src下面只有.v设计文件,怎么产生了
design_core.db库文件呢?而且我设置过综合的target_library是DC目录下synopsys的库,怎么产生了上面那个design_core.db库呢?请大侠们指教啊...
==================================log===================
read_file -format verilog {/home/project/syn/src/design_core.v}
Loading db file '/eda/synopsys/dc2008_09/libraries/syn/gtech.db'
Loading db file '/eda/synopsys/dc2008_09/libraries/syn/standard.sldb'
  Loading link library 'gtech'
Loading verilog file '/home/project/syn/src/design_core.v'
Detecting input file type automatically (-rtl or -netlist).
Running DC verilog reader
Reading with Presto HDL Compiler (equivalent to -rtl option).
Running PRESTO HDLC
Compiling source file /home/project/syn/src/design_core.v
set_driving_cell -lib_cell PS_IBUF -pin Z [all_inputs]
Warning: Design 'design_core' has '2' unresolved references. For more detailed information, use the "link" command. (UID-341)
Error: Cannot find the specified driving cell in memory.   (UID-993)
 楼主| 发表于 2014-5-18 21:13:08 | 显示全部楼层
顶起来。、
发表于 2014-5-22 14:11:33 | 显示全部楼层
link库里没有IO lib
 楼主| 发表于 2014-5-22 15:14:42 | 显示全部楼层
发表于 2014-5-22 20:08:42 | 显示全部楼层
回复 4# ICSYS
1. STD2. IO
3. Memory
4. other Macro IP
发表于 2014-5-22 21:26:25 | 显示全部楼层
多谢分享
发表于 2018-3-19 10:01:29 | 显示全部楼层
回复 5# richardxingxing
   谢谢,顺便记录下。
GMT+8, 2025-8-30 02:36 , Processed in 0.014211 second(s), 3 queries , Gzip On, Redis On.
