登录 注册
手机短信,快捷登录
查看: 16626|回复: 12
cannot compile ahdlcmi module(已经看过论坛相关帖子,确定无重复,谢谢大侠们!)
发表于 2013-5-9 20:06:40 | 显示全部楼层 |阅读模式
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.2.0.109 32bit -- 6 Dec 2009
Copyright (C) 1989-2009 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
        5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
        6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
        6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
        6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
        7,085,700; 7,143,021; 7,493,240; 7,571,401.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: appleyuchi   Host: localhost   HostID: 7F0100   PID: 5137
Memory  available: 439.6933 MB  physical: 2.1142 GB
CPU(1 of 1):  CPU 0  Intel(R) Celeron(R) CPU 2.66GHz  2660.097MHz
Simulating `input.scs' on localhost at 7:56:19 PM, Thur May 9, 2013 (process id: 5137).
Command line:
        /home/appleyuchi/Cadence/IC5141/MMSIM7/tools.lnx86/spectre/bin/32bit/spectre  \
        -env artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre0_4004_1 -format sst2 -raw ../psf +lqtimeout  \
        900 -maxw 5 -maxn 5 input.scs
spectre pid = 5137
Loading /home/appleyuchi/Cadence/IC5141/MMSIM7/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /home/appleyuchi/Cadence/IC5141/MMSIM7/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /home/appleyuchi/Cadence/IC5141/MMSIM7/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /home/appleyuchi/Cadence/IC5141/MMSIM7/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Auto-loading AHDL component.
Finished loading AHDL component in 0 s (elapsed).
Installed AHDL simulation interface.
Warning from spectre in `NS', during circuit read-in.
    WARNING (SFE-2296): "/home/appleyuchi/Cadence/IC5141/L50G_V2.scs" 973: The inline subckt definition `NS' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Warning from spectre in `PL', during circuit read-in.
    WARNING (SFE-2296): "/home/appleyuchi/Cadence/IC5141/L50G_V2.scs" 1061: The inline subckt definition `PL' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Warning from spectre in `PS', during circuit read-in.
    WARNING (SFE-2296): "/home/appleyuchi/Cadence/IC5141/L50G_V2.scs" 1155: The inline subckt definition `PS' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Warning from spectre in `NK', during circuit read-in.
    WARNING (SFE-2296): "/home/appleyuchi/Cadence/IC5141/L50G_V2.scs" 1248: The inline subckt definition `NK' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Warning from spectre in `NQ', during circuit read-in.
    WARNING (SFE-2296): "/home/appleyuchi/Cadence/IC5141/L50G_V2.scs" 1335: The inline subckt definition `NQ' does not contain any inline components. The `inline' qualifier will therefore be ignored.
        Further occurrences of this warning will be suppressed.
Opening directory input.ahdlSimDB/ (775)
Created directory input.ahdlSimDB/96_home_appleyuchi_Cadence_IC5141_cap1.va.mosCap.ahdlcmi/ (775)
Created directory input.ahdlSimDB/96_home_appleyuchi_Cadence_IC5141_cap1.va.mosCap.ahdlcmi/Linux3.2.0-4-686-pae+gcc/ (775)
Compiling ahdlcmi module library.
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/96_home_appleyuchi_Cadence_IC5141_cap1.va.mosCap.ahdlcmi/Linux3.2.0-4-686-pae+gcc/ for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (VACOMP-1697): "parameter real (*integer inherited_mfactor; *) m=1;<<--? "
        "Internal (bsource)", line 382: Attempting to redefine identifier 'm'. Remove the extra definition or use a different identifier.
spectre terminated prematurely due to fatal error.
发表于 2013-7-7 14:22:40 | 显示全部楼层
回复 1# appleyuchi2
    请问你这问题最后是怎么样解决的?
 楼主| 发表于 2013-7-7 23:24:29 | 显示全部楼层
回复 2# 腐朽的青春99
    请加下我QQ:753743312
最近忙项目,有空qq聊吧~
发表于 2013-7-8 14:56:15 | 显示全部楼层
回复 3# appleyuchi2
    谢谢
 楼主| 发表于 2013-9-1 03:51:11 | 显示全部楼层
回复 4# 腐朽的青春99
    把我qq拉黑了?算了,随你吧。。。。。
发表于 2014-4-23 15:39:20 | 显示全部楼层
楼主解决没,我遇到同样问题
发表于 2014-4-23 20:51:47 | 显示全部楼层
我也遇到这个问题了
发表于 2014-8-28 14:07:57 | 显示全部楼层
同求解答  是不是我少安装了别的东西,按照提示  我 找到了具体提示文件里的内容   见附件   求指导
发表于 2014-11-19 14:08:11 | 显示全部楼层
回复 5# appleyuchi2
大哥   怎么解决的呢?
发表于 2016-8-4 18:05:12 | 显示全部楼层
此问题最后有解决吗?
GMT+8, 2026-2-14 17:12 , Processed in 0.117613 second(s), 3 queries , Gzip On, Redis On.
