查看: 11050|回复: 20
[求助] 求助:generated layer算法
发表于 2013-6-4 11:15:01 | 显示全部楼层 |阅读模式
请教论坛各路高手,generated layer的算法是什么样子的?
举个例子,我用的是gb35工艺,其中TN层是用这个算法产生的:
(((((Ncomp AND Dualgate)@ 0.15) AND (NOT(Pcomp @ 0.15)))@ 0.15) @0.3)@-0.3
我要请教一下,[url=mailto@0.15]@0.15[/url],@0.3,@-0.3,这都是什么意思啊?哪里有这个语法的介绍?谢谢!
发表于 2013-6-4 15:31:18 | 显示全部楼层
乱码吧你这?层的操作就是与,与非这样子类似操作.与的话就是取共同的部分,与数字里面的与运算不同.想理解更深的话,可以用layout试一下.
发表于 2013-6-4 15:37:17 | 显示全部楼层
会不会是sizing的意思。。。lz不行就把pdf发上来吧
 楼主| 发表于 2013-6-4 17:23:12 | 显示全部楼层
回复 3# allen_tang
The following layers are not drawn, but generated from a drawn layer through data manipulation. Please refer to process information (located after the table) to select the correct generation
Layer
Name
Process
Description
Algorithm
Digitized Polarity
Comments
COMP
All
Union of Ncomp and Pcomp
Ncomp OR Pcomp
Dark
PField
Native VT NMOS
Reverse of union of CDPwelland Nwell
CDPwell OR Nwell
Dark
PField and Nwell cum CDPwell are of different polarity, therefore PField Algorithm is the same as Nwell and CDPwell even though description calls for reverse tone of CDPwell and Nwell
All others Analog & All Logic
Reverse tone of Nwell
Nwell
Dark
Same comments as PField layer above
Pplus
All
0.30 µm oversize of Pcomp.
No oversize at Pcomp edge butted to Ncomp. Merge if space is less than 0.6µm
after generation.
((((Pcomp@ 0.15) AND (NOT(Ncomp@ 0.15)))@ 0.15) @ 0.3) @-0.3
Clear
Process Information
Each process id will have the following process id attributes available inside PLM database. Please inform process owners if one of attributes described here are ‘Blank’ or no value.
For Native VT NMOS process, ‘VT Options’ must have the word ‘Native VT’:
就是这个样子的了
附件是globalfoundry0.35um工艺的design rule
yiminus046minusdr002_rev_14_7feb2013.docx (594.33 KB , 下载次数: 21 )
发表于 2013-6-4 18:37:56 | 显示全部楼层
那些数字看起来是涨缩量。其他的就是逻辑生成,AND, NOT之类的。A AND B 即A B 共有的地方。A NOT B 即A没有B的地方。(NOT有方向性,A,B位置调换,得出的结果不一样)仅供参考。
发表于 2013-6-4 18:40:30 | 显示全部楼层
看不清你那个语句。一般对某个层次进行先缩在涨的目的,都是为了把小于某些尺寸的图形去掉。
 楼主| 发表于 2013-6-4 18:44:11 | 显示全部楼层
多谢各位高手指点,我大概懂了,现在只有最后一个问题,那个@-0.3是什么意思?为什么会出现负数?
发表于 2013-6-4 20:24:58 | 显示全部楼层
回复 7# humphreyyu
    size嘛,当然可以是正,也可以是负了。不过我好没有弄明白为什么,比如(A size 0.5)size -0.5,这种我遇到好多,不过当时缺乏好奇心,没有问foundry。
 楼主| 发表于 2013-6-5 11:05:28 | 显示全部楼层
回复 8# allen_tang
    请问,这些算法看不懂,怎么知道这一层是否会产生呢?做JDV的时候怎么判断maskshop生成的mask是否正确?
发表于 2013-6-5 11:20:10 | 显示全部楼层
logic operation就是干这些and,or,not,xor ,sizup/down的事情,看多了就麻木了,
GMT+8, 2025-12-5 17:46 , Processed in 0.019131 second(s), 4 queries , Gzip On, Redis On.
