发表于 2013-4-10 15:13:41
显示全部楼层
The save Parameter Options
The following table shows the possible settings for the save parameter:
Setting Action
none Does not save any data (currently does save one node chosen at random).
selected Saves only signals specified with save statements. This is the default
setting.
lvlpub Saves all signals that are normally useful up to nestlvl deep in the
subcircuit hierarchy. This option is equivalent to allpub for subcircuits.
Normally useful signals include shared node voltages and currents through
voltage sources and iprobes.
lvl Saves all signals up to nestlvl deep in the subcircuit hierarchy. This
option is relevant for subcircuits.
allpub Saves only signals that are normally useful. Normally useful signals include
shared node voltages and currents through voltage sources and iprobes.
all Saves all signals.
Use lvl or all (instead of lvlpub or allpub) to include internal node voltages and
currents through other components that compute current.
Use lvlpub or allpub to exclude signals at internal nodes on devices (the internal collector,
base, emitter on a BJT, the internal drain and source on a FET, etc). lvlpub and allpub
also exclude the currents through inductors, controlled sources, transmission lines,
transformers, etc.
Note: Setting the save parameter value to selected without any save statements in the
netlist is not equivalent to specifying no output. Currently, the Spectre simulator saves all
circuit nodes and branch currents with this combination of settings. This might change in
future releases of the Spectre simulator. |
