查看: 3002|回复: 4
[原创] ccs_lib problems
发表于 2013-1-18 18:17:27 | 显示全部楼层 |阅读模式
请问各位大侠个ccs lib的问题。
在ccs lib中,为了仿真计算delay值,建模为driver model ,reduced-order network model 和receiver model。
在receiver model中,分为pin-based receiver model和arc-based receiver model,请问这两个model的区别,
什么样的是pin-based receiver model,什么样的是arc-based receiver model?
谢谢!
发表于 2013-1-19 21:55:33 | 显示全部楼层
查solvnet, library compiler的文档吧,  太细了
 楼主| 发表于 2013-1-20 16:17:34 | 显示全部楼层
回复 2# icfbicfb
   谢谢版主,我查过资料和solvnet,还是不太理解怎么区分,好像是基本cells(buf,inv等等)的pins都是arc-based model,而像FFs的D pin就是pin-based model。但是还是对这两个概念模糊不清。
望指教!!!
发表于 2013-6-30 21:36:51 | 显示全部楼层
哥,崇拜你啊,我从来都是把ccs直接拿来用,压根就没有去看这些库怎么算出来的,留个qq一起讨论哈
发表于 2013-8-23 15:45:32 | 显示全部楼层
回复 3# wxcarson
Arc-based is timing based, there is miller effect from the related output pin cap.
Pin-based means that the receiver pin has little dependency on the related output pin cap with its corresponding driver model.
GMT+8, 2025-11-13 04:48 , Processed in 0.015902 second(s), 3 queries , Gzip On, Redis On.
