查看: 35653|回复: 50
[求助] 求助,怎样通过仿真得到阈值电压和uncox的值
发表于 2012-12-6 11:08:15 | 显示全部楼层 |阅读模式
各位前辈,我是研一学生,最近在使用0.25um工艺进行仿真设计放大器,然后进行仿真求uncox和阈值电压,但是总能得到不同的结果,另外,spice仿真模型中的沟道长度调制系数怎么查?下面是工艺库文件的NMOS模型,跟拉扎维等书上的模型不全相同,尤其没找到沟道长度调制系数在哪,希望各位前辈指点。
.MODEL nch.1            NMOS   (                    LMIN     = '1.2E-06-dxl'
+CALCACM = 1              SFVTFLAG = 0              VFBFLAG  = 1
+LMAX    = 2.1E-05        WMIN     = '1.2E-06-dxw'  WMAX     = 1.01E-04
+LEVEL   = 49             TNOM     = 25             XL       = '3E-08+dxl'
+NLEV    = 3              AF       = 0.8824         KF       = 3.454E-24
+XW      = '0+dxw'        VERSION  = 3.2            TOX      = toxn
+XJ      = 1E-07          NCH      = 1.63E+17       LLN      = 1
+LWN     = 1              WLN      = 1              WWN      = 1
+LINT    = 2E-08          WINT     = 2E-08          MOBMOD   = 1
+BINUNIT = 2              DWG      = 0              DWB      = 0
+VTH0    = '0.4767749+dvthn' LVTH0 = 3.507137E-08   WVTH0    = -1.453229E-08
+PVTH0   = -6.620086E-15  K1       = 0.4472964      LK1      = -5.39693E-08
+WK1     = -4.269873E-08  PK1      = 5.981896E-14   K2       = 0.004538423
+LK2     = 2.041006E-08   WK2      = 1.682965E-08   PK2      = -2.784819E-14
+K3      = 0              DVT0     = 0              DVT1     = 0
+DVT2    = 0              DVT0W    = 0              DVT1W    = 0
+DVT2W   = 0              NLX      = 0              W0       = 0
+K3B     = 0              VSAT     = 120633         LVSAT    = -0.01265326
+UA      = -9.218065E-10  LUA      = -1.161761E-16  WUA      = 1.451009E-16
+PUA     = -5.566174E-23  UB       = 1.81497E-18    LUB      = 1.561614E-25
+WUB     = -2.338524E-25  PUB      = 8.58042E-33    UC       = 4.365745E-11
+LUC     = 8.007525E-18   WUC      = -7.436576E-18  PUC      = -6.149303E-24
+RDSW    = 187            PRWB     = 0              PRWG     = 0
+WR      = 1              U0       = 0.03077917     LU0      = 5.598957E-11
+WU0     = -8.158919E-11  PU0      = 1.090017E-15   A0       = 0.5252816
+LA0     = 4.042826E-08   WA0      = 1.225374E-07   PA0      = -2.063631E-13
+KETA    = 0.003461425    LKETA    = -9.223886E-09  WKETA    = -8.366612E-11
+PKETA   = 1.672486E-15   A1       = 0              A2       = 0.65
+AGS     = 0.01           B0       = 0              B1       = 0
+VOFF    = -0.1517445     LVOFF    = 2.086556E-08   WVOFF    = 6.482217E-09
+PVOFF   = -7.791971E-15  NFACTOR  = 1              CIT      = 0.000377699
+LCIT    = 7.405382E-10   WCIT     = -6.34899E-10   PCIT     = 7.555298E-16
+CDSC    = 0              CDSCB    = 0              CDSCD    = 0
+ETA0    = 3.836953E-05   LETA0    = 2.324929E-10   WETA0    = 8.055062E-12
+PETA0   = -1.610206E-16  ETAB     = -4.68351E-05   LETAB    = -6.326623E-11
+DSUB    = 0              PCLM     = 0.4755805      LPCLM    = 4.88145E-07
+WPCLM   = -6.231367E-09  PPCLM    = 1.245653E-13   PDIBLC1  = 1E-05
+PDIBLC2 = 0.0002151594   LPDIBLC2 = 5.69396E-09    PDIBLCB  = 0.01
+DROUT   = 0              PSCBE1   = 1.213673E+08   LPSCBE1  = 265.5531
+WPSCBE1 = -3.167115      PPSCBE1  = -1.324478E-05  PSCBE2   = 1E-06
+PVAG    = 0              DELTA    = 0.01           ALPHA0   = 4.200379E-06
+BETA0   = 20.54463       KT1      = -0.2402984     LKT1     = -1.511487E-08
+WKT1    = 1.116811E-08   PKT1     = -1.329005E-14  KT2      = -0.02232689
+LKT2    = -1.527194E-08  WKT2     = -1.12105E-08   PKT2     = 1.287179E-14
+AT      = 35000          UTE      = -1.688541      LUTE     = 3.778586E-09
+WUTE    = 1.029916E-07   PUTE     = -5.895606E-14  UA1      = 9.999999E-11
+UB1     = 0              UC1      = -4.534566E-11  LUC1     = 7.638851E-17
+WUC1    = 8.059368E-17   PUC1     = -8.934457E-23  KT1L     = 0
+PRT     = 0              CJ       = cjn            MJ       = 0.4708251
+PB      = 0.9597901      CJSW     = cjswn          MJSW     = 0.379613
+PBSW    = 0.9597901      CJSWG    = cjgaten        MJSWG    = 0.379613
+PBSWG   = 0.9597901      CTA      = 0.0007391288   CTP      = 0.0009081566
+PTA     = 0.001293296    PTP      = 0.001178533    JS       = 2E-06
+JSW     = 5E-10          CGDO     = cgon           CGSO     = cgon
+CAPMOD  = 3              NQSMOD   = 0              XPART    = 1
+CF      = 0              TLEV     = 1              TLEVC    = 1
+XTI     = 3              N        = 1              HDIF     = hdifn
+LDIF    = 1.2E-07        RSH      = 4.5            RS       = 0
+RD      = 0              ACM      = 12             DLC      = 3.49e-9
+DWC     = 5.76e-10       CLC      = 3.82E-08       CLE      = 0.6972
+ACDE    = 0.4            MOIN     = 10             NOFF     = 1.4959
+VOFFCV  = -0.074         CKAPPA   = 2.8769          CGDL    = cgln
+CGSL    = cgln           CGBO     = 1E-13           TOXM    = 5.4E-9)
发表于 2012-12-6 14:56:39 | 显示全部楼层
你仿真一个DC就可以看到vth的
 楼主| 发表于 2012-12-6 20:25:26 | 显示全部楼层
谢谢前辈,不过我仿真后发现,加负载和不加负载得出的阈值电压不同,是不是应该在不加负载的前提下得到的阈值电压才是正确的?
回复 支持 0 反对 1
 楼主| 发表于 2012-12-6 20:27:10 | 显示全部楼层
谢谢前辈,我进行DC仿真后发现,有负载和没有负载的情况下得到的阈值电压不同,是不是没有负载的情况下得到的才是正确的阈值电压?
发表于 2013-1-10 09:06:01 | 显示全部楼层
mosfet 2.5V.docx (345.44 KB , 下载次数: 2035 )
mos管常用工艺参数仿真方法
发表于 2013-8-20 19:42:34 | 显示全部楼层
回复 5# xiarilianqu001
    好人,好人
发表于 2013-8-29 22:48:19 | 显示全部楼层
能提供一下mos管常用工艺参数在HSPICE仿真时的几个函数吗?
发表于 2014-6-26 15:28:29 | 显示全部楼层
多谢啦
发表于 2014-6-27 09:33:33 | 显示全部楼层
看一下
发表于 2014-7-17 10:32:42 | 显示全部楼层
不错不错
GMT+8, 2025-11-5 07:51 , Processed in 0.028931 second(s), 8 queries , Gzip On, Redis On.
